LifeAsDane
Dane
SW Florida
22' Lightning SR Lariat | 13' F150 EB Lariat
Real Estate
VIDEO: Full Walkaround Wrap + Tint
TINT: Brutal summer in Florida had Window Tinting as a top priority. Decided on a shop using XPEL PRIME XR Black. They measured the existing glass tint from the factory for the back windows to make sure it matched up with the Front windows for a nice even look around. Also went with a 70% front window shield tint to protect the dash a little and help with glare.
LED Light Bar WRAP: Now the wrap ended up being a bit tricky for the shop I went to. Partially due to how new this truck is and them not having many forums or references to go to for the application. They started with around a 3.5mm thick vinyl that was giving them a lot of problems due to how deep the led bar goes back under the hood and trying to get full coverage plus handle all the angles. After a few hours, they told me they'd need a full day to get it right so I picked up my truck to bring back the following week. They found XPEL had a template online for our LED Bars but they (XPEL) had no feedback yet from any installers about the template. Long story short the product is better as it's an 8mm wrap BUT there are exposed areas all around due to the template design and limitations of some of the angles present. Overall I was happy with the final result and the amount of time the shop invested into getting this done as best they could. I know they ended up eating some cost due to the time and using the XPEL product but the exposed areas are mainly noticeable to me and knowing how it looked before, but it's 100x better than the OEM look and how much the light bar stood out on the Stone Gray color. If anyone is interested in additional angles I can add some different shots at night and other angles.
Ford F-150 Lightning XPEL Window TINT & Front Light Bar WRAP installed 20230809_123136
Ford F-150 Lightning XPEL Window TINT & Front Light Bar WRAP installed 20230809_105110
Ford F-150 Lightning XPEL Window TINT & Front Light Bar WRAP installed 20230728_151930
ranger5ft21
Rick
2023 F150 Lightning Lariat ER
I tried to get my window tint shop to do the lightbar, but they passed after doing some reserach because how far the lightbar goes back, they thought was it was going to be too much trouble. Can you take pictures of the areas that are covered as much. I might call them back up and tell them about XPEL's template.
boggle
CT
MY23 PRO
Also have the Stone Gray, the milk jug lights look comically cheap on it. I don't know what Ford was thinking. Going to pull my headlights and try to tackle this with a buddy who does vinyl. Sucks XPEL still doesn't have them figured out.
LifeAsDane
LifeAsDane
Dane
SW Florida
Real Estate
I'll do a short video and post to YouTube and notify when done
trailcat
WA
F-150 Lightning - Lariat ER
I like the look! It takes away that cheap plastic feel big time.
What % was used on the front windows to match the rear?
Simpso57
Rob
Ford F150 Lightning
My tint guy started and decided the angles made it too difficult. Said best method is to take it out and spray it. Ford should have tinted it to begin with.
Your truck looks great.
KevinC
Kevin
MO
I really like how your light bar turned out. I've wondered if the white light bar would end up looking extremely dated after a few years and possibly even awkwardly faded.
doolin64
Dudley, MA
2021 F150 Lariat Powerboost & 2019 Mustang GT Conv
Real estate
Are these the exposed areas you were talking about? I look forward to more pictures and with the light on. I think it looks great.
Ford F-150 Lightning XPEL Window TINT & Front Light Bar WRAP installed tint
LifeAsDane
LifeAsDane
Dane
SW Florida
Real Estate
Here you go!
https://youtu.be/g8lUNQnztzA
trailcat
WA
I like how the tint on the lightbar blends in with the grill and stone gray. Nice ride!
Do you remember the tint % used on the front windows?
brewski
GA
2023 F150L Platinum
Yes
I did xpel on hood (bikini cut), grill (I don't recommend), front bumper, mirrors, A-pillars and leading edge of the roof. My installer was/is very open to coming back and having him fix bubbles, etc.
I'm guessing since xpel is a wet application product vs "normal" wrap being dry, you can't do corners the same.
Xpel has multiple cut-outs on tough corners.
4seaer
Steven
2024 ford f150 lightning
Ford F-150 Lightning XPEL Window TINT & Front Light Bar WRAP installed IMG_3659
Ford F-150 Lightning XPEL Window TINT & Front Light Bar WRAP installed IMG_3658
Ford F-150 Lightning XPEL Window TINT & Front Light Bar WRAP installed IMG_3657
Ford F-150 Lightning XPEL Window TINT & Front Light Bar WRAP installed IMG_3647
