didiasku
thought I'd tinker a bit...I tried enabling the side mirror reverse tilt and now having issue
1) when selecting the left or right mirror while in reverse, they tilt down, but the left mirror keeps trying to pan down indefinitely while the right mirror tries to pan right indefinitely (clicking mirror noise)
2) so i thought ok, this isn't going to work, I changed back the APIM and IPC settings to the original (no tilt)
3) ive power cycled and now if I'm in reverse and select a mirror, it continues to do the erroneous behavior.
Not a huge issue as I have no reason to select a side mirror in reverse (without reverse tilt working) however, I am curious as to why configuring these 2 settings back to their defaults, the mirrors still operate as if "reverse tilt" is enabled.
thoughts/help?
Problem solved...had to enable reverse mirror tilt on APIM, go to settings, then mirror, then turn off reverse mirror tilt.
thoughts/help?
