Jesse-Infotainment
I am going to try and be more active this coming year. I havent been because of different things. Unfortunately the only real way to know is if they plug in. It polls the modules plus if I pull your vin on my bench it will show in the history. Anything done if I were to pull your vin in Oasis or in FDRS would be reflected in the vehicle history. I try not to pull a vin unless absolutely necessary with the newer stuff.You sir are amazing! Most people wouldn’t go through the trouble of adding all the items you have. Nice to know there are still a lot of tinkerers out there.
Are you able to check a VIN and see if there are any issues with the OTA status or module versions/calibrations? Mine I believe is stuck on an update after 1.6 and FORD has been no help when trying to understand the issues.
My VIN is: 1FTFW1ED0MFB66211
The best and most accurate would be to plug in and open FDRS. Do you know when yours was built?
