wayfarer556
Austin, TX
2021 F150 XLT Powerboost 302A
I got an getting an “Oil reporting low.” I got an oil change at the dealer just yesterday…
edit: it went away after an hour.
tonesto7
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
I just wanted to say Happy Holidays to everyone! I hope you have a great day with family and friends.
I will be releasing some updates tomorrow that clean up the layout and make the elements line up better (icons and text are now center aligned), remove labels on items with icons for the small widgets, and
I've rewritten the widget tool. It now manages the creation and updating of multiple instances of the widget (no more editing the SCRIPT_ID tag).
This will require you to update the widget tool (basically you need to use the installer and it will overwrite the old tool with the new)
I just need to update the docs and videos tomorrow before I can release :)
Kanuck
Don
Manitoba
2021 Super Cab Carbonized Grey 3.5 EC 302A 6.5 Box
Electrician, Retired
You sure have made me jealous not being able to run this in my LG... is there anyway around this issue? Great work BTW. Still jealous...LOL????
wayfarer556
Austin, TX
Thanks for writing this out. This is a gem.
Icecoldak
Steve
Alaska
2019 F-150 Limited
Merry Christmas!!
I have run this script and every update of it--and I still cannot get the (4)windows to show correctly (always Red X) they have never worked for me, and the LF door always red X as well!!
don.mullins
Don
McKinney, TX
2021 F-150 3.5 Powerboost Platinum
Since I already had AT&T, my truck was just adding an additional device.
It is $14.94 / month including fees.
tonesto7
tonesto7
Anthony
NEW Releases:
Fordpass Widget (v1.4.0)
  • Fixed local vehicle data file to support multiple instances.
  • Fixed data scrubber to scrub out relevantVin keys.
  • Removed the low oil life warning for now.
  • Menu optimization to reduce the number of menu items. Lock and remote start are now submenus and they are officially only shown to supported vehicles.
  • Added Horn/Lights control to the main menu for supported vehicles.
  • Fixed a lot of the text and image alignment in the widget.
  • Reworked the small widget to not show text on labels with icons.
  • Added door and window status to the small widget.
  • Added a nicely formatted breakdown of the OTA data about the raw data.
FordWidgetTool (v1.1.0)
  • Supports updating multiple instances and managing the SCRIPT_ID value.
  • It's now used to create and remove additional instances of the script.
  • It can now remove and clean up all widget instances and their data.
Please note that you will need to run the installer again to update the widget tool.
Once the widget tool is updated it will popup a menu offering to update your existing widgets.
Download | Upgrade Link:
Ford Widget Tool Installer (tonesto7.github.io)
Documentation:
tonesto7/fordpass-scriptable: FordPass Widget for Scriptable (github.com)
Community:
Discord: https://discord.gg/VPw3zw9v
jarcher
Canada, AB, Calgary
2021 F-150 Tremor (ordered), 2014 Focus ST
Construction
Wow that widget tool makes the updates so easy now!
tonesto7
tonesto7
Anthony
jarcher
Canada, AB, Calgary
Construction
Mxp0w3r25
Anthony
2021 F150 Lariat Powerboost
Systems Engineer
NEW Releases:
Once the widget tool is updated it will popup a menu offering to update you existing widgets.
Documentation:
Community:
Thanks again for this work!
Copperhaun
Jered
SLC, UT
‘21 STX Screw 157” wb
Peasant
Has anyone pinned down a way to add a Siri shortcut to start your truck with just a Siri command?
Sapphire
Chicago
2021 F-150 Powerboost Platinum
LeadBoost
Joe
2021 Ford F150 XLT 302A
Structural Steel Sales & Marketing
Tried to install the new 1.4 update and got an error: "2021-12-28 08:58:26: Error on Line 15:70: iCloud is not supported. Make sure that you are logged into iCloud in the device settings."
iCloud is enabled on my phone, and my app is toggled "on" under the iCloud settings.
Update: That error has gone away, my iCloud Drive was off. I now get an error saying" Error on Line 30:32: "FordPass 1.4.js" couldn't be removed."
tonesto7
tonesto7
Anthony
I have the core logic in the script that will work with a Special shortcut allowing any supported command to be submitted to the widget. I just need to build out the parser. It will allow for far more advanced commands.
This is coming in v2.0 of the script.
No more need for multiple shortcuts it will all be handled by the same widget script and a single shortcut.
