He did mention fact that this truck is likely going to be hard to find at this price. His expertise is in the math not car specs is 9.6 vs 7.2kwConclusion seems obvious before even watching (which I did), but you are going to enrage those who wish to purchase a Lightning Pro. Especially because he said consumers can buy it...
I wonder if he thinks the outlet in the back puts out 9.6kW... it is only 7.2kW.
There is no reason you would need 320 amp service to backup power if your service is now 200 amps. Phyics sizes the wire from the panel to the pole based on the number of amps of power that the pole might sent to the house. your having backup power doesn't make more power go down the pole. That being said charging 80 amps on a 200 amp service might be totally fine or could be a lot depending on your normal usage. I dont know if anyone makes a smart charger that measures the rest of your usage and lowers down charging when needed.. I think in most cases you can only set a max charge.. But maybe some beast existsI wonder if he got his 320amp line (on the board, saying you need 320amps to take advantage of the backup power) off of the ford site?
I messaged Tom Moloughney on twitter asking this same question and he said 200 amp service will suffice in many cases. In that chain, Mike Levine and Emma Bergg liked his tweet. So I am going to assume they agree w/ his comment about the 200amp service. He said he'll post something soon up on his Youtube going over the whole intelligent backup system.
It seems that without the Ford/Sunrun HIS the truck can't be coaxed into putting out HVDC through the FCSP connector. To use the F150L is place of a Powerwall would then require additional hardware and hooking up to truck bed connector every time you parked the vehicle. In this regard the Powerwall would be favored.He did mention fact that this truck is likely going to be hard to find at this price. His expertise is in the math not car specs is 9.6 vs 7.2kw
Except you can’t do that!Use the 80amp return service from the truck and power the house overnight, charge during the day with solar.
There would be so many third party solutions possible that would outperform the Ford/HIS system if the HVDC could be activated without whatever proprietary system the HIS uses. It's a shame that Ford has kneecapped the utility of the truck with this limitation.Except you can’t do that!
Ah I see it can only return 40amps through the pro-power charger. 40amps is still enough to power a lot of stuff.Except you can’t do that!
The PP inverters don't have synchronized outputs so realistically the limit is 30amps which is still plenty for most backup power needs.Ah I see it can only return 40amps through the pro-power charger. 40amps is still enough to power a lot of stuff.
