780
Perfect. Thank you.No, you can select Turbo Boost gauge as one of two selectable gauges at the top of your screen through the Menu accessed on the steering wheel. At least you can with my XLT 302A.
I don't have that option on my Nov 2021 build 302aNo, you can select Turbo Boost gauge as one of two selectable gauges at the top of your screen through the Menu accessed on the steering wheel. At least you can with my XLT 302A.
I didn't think mine had it either, but I finally found it. Mine is a 22 though...I don't have that option on my Nov 2021 build 302a
Mine's a 2021 built in Nov too. It's there but buried under a bunch of clicks. I'll try to put together a walkthrough tonight...I don't have that option on my Nov 2021 build 302a
What I posted is what I have after menu/settings. Only those two next options.MENU button on steering wheel, Settings, Configure Gauges, select Left or Right Selectable Gauge
You have a PB so chances are different instrument cluster options.What I posted is what I have after menu/settings. Only those two next options.
You have another page of options, push Up or Down arrow to scroll between pages. I can tell by the narrow blue line on the right side of the box.What I posted is what I have after menu/settings. Only those two next options.
When I push up or down it toggles between Neutral Tow and Vehicle Maintenance. It doesn't go higher or lower beyond those two.You have another page of options, push Up or Down arrow to scroll between pages. I can tell by the narrow blue line on the right side of the box.
I stand corrected. After another attempt, I was able to get to a second screen to find more settings. The dash UI/UX could use some polishing. I now have boost where oil pressure used to be on the left. Thank you!You have another page of options, push Up or Down arrow to scroll between pages. I can tell by the narrow blue line on the right side of the box.
Nice! Turbo is such valuable information. Who even knows what to do with Oil Pressure anyway? Mine could say "eleventy billion pressure units" and I'd just be like, "ok".I stand corrected. After another attempt, I was able to get to a second screen to find more settings. The dash UI/UX could use some polishing. I now have boost where oil pressure used to be on the left. Thank you!
