UGADawg96
Just be careful with assumptions for payload and TT published weights. I'm dealing with the same thing currently. I started with 1523 lb payload as built. I added 500 lb of humans, 300 lbs of E rated tires, line-x, WDH, and a couple misc. items. Our spec'd TT (Imagine 2250rk - 28') of 5546 UVW and 515 hitch is actually 6440 (without water) and 840 tongue weight. This puts us at 70 lb over payload (GVW). See thread with updates as recent as this past weekend with multiple weightings. https://www.f150gen14.com/forum/threads/first-time-on-cat-scales-with-pb-and-tt.7811/ The PB makes towing worse than the regular 3.5 since you lose payload and the additional torque isn't really necessary when payload gets maxed out before tow capacity (which is all marketing anyway). Except having the 7.2kw geny is gold for boondocking, home power failures, tailgating, or any other geny needs. If they were to make a F250 with the 7.2kw or higher, I'd be very tempted to upgrade.This has been my major epiphany today. I am looking to upgrade from my '17 f150 lariat 2.7l eb 4x2 to a '22 f150 lariat pb 4x4 and what I've sort of realized is my towing capacity (limited by payload) won't be that much better. Some of that loss is from the pb batteries and motor and some from the 4x4.
I'm novice when it comes to towing and I'm at the point of rethinking my whole plan. Granted I don't plan to tow often, but thought about getting a TT for some family vacations. Now I'm not sure that will be feasible with the truck I'm getting (I need to wait till next week to see the payload numbers for that specific truck).
If the payload is around 1300-1400 I'm no better than what I have as I feel I'll be limited to what I guess is under 5-6k of towing capacity. The only benefit will be from the 3.5l eb portion of the pb as from what I've read the hybrid doesn't help too much overall when towing.
