JEB
Northern Illinois
2021 F-150 Lariat Powerboost
1. GWM
2. TRM
3. DDM
4. PDM
5. DSP
6. SCCM
7. CCM - This will also do the PSCM & IPMA
I think as a general rule you should ALWAYS update the GWM first, if an update is available. The GWM is basically just a router—it processes communications among networked modules within the truck and then communicates with Ford via the TCU (a fancy name for modem). I could see real problems developing if you update another networked module before you apply any available updates to the GWM because an older version of the GWM software might not have the newest list of module addresses. So, an out of date GWM might not know where to deliver the mail.
iceman77
Pete
2022 Ford F-150 Platinum
NOTICE: There seems to be a problem flashing the CCM module with the latest BC activation package. I have had 2 users already reporting a failure during the block erase process
Can anyone who has successfully completed the CCM module flash reach out to me and share their VIN ? Me and @Jesse-Infotainment are trying to figure out if right files are being flashed to your module or not. This could be another IPC like situation and we want to be aware of it
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
I had success this morning and you should have my VIN and, back a few posts I posted the before and after the 2.5.1 update.
jmm3807
Phoenix AZ
www.seasavvyaquarium.com
2021 F-150 Platinum 4x4
Business Owner
Just an update from my truck. IPMA generally has DTC come back after driving it. However it’s U2400 = Ethernet Failure With Gateway Module A (GWM) and I think Jesse Infortainment mentioned this would correct with future update. Everything else checks out as far as I can’t tell.
The only other issue that comes up is the power steering control module reporting offline briefly then coming back once I clear and rerun tests.
abd79
Wayne
2021 F-150
I did mine yesterday without issue and you should have my VIN also already.
Jesse-Infotainment
2021 F150
This happens from time to time. The ethernet failure is not anything to worry about. It It happens after updates. Ive had it and they even had a note about it happening after a gateway update. If it came back it will clear itself after a while. The ethernet is only used for OTA updates and USB updates. If that is the only thing you are in good shape and enjoy the new cam features
Jesse-Infotainment
2021 F150
Those that had success with the CCM, do you have a power boost?
Jaug
Jason
Fargo
2021 F150 Platinum
The ones that failed, did you use a nano or Mongoose? Which version of FDRS? I think on the Mach e forum someone said the new FDRS version might have a cache issue, not sure if that matters or not, I am not computer savvy enough.
Jesse-Infotainment
2021 F150
I was just asking iceman this same thing! These are fd can devices and the nano is not fd can compatible from what I’ve seen. There was a guy that had 4 devices on fd can go purple the dealer fixed it.. I’m sure they just ran a PMI and it worked. I’ll have to look at his vin..
If that was you can you send me you vin please so I can look
