2022 Lariat cargo light wiring harness parts
Genoz
Eugene
2022 F-150 Lariat
Anyone know the part numbers for the wiring harness both right and left sides? I already have the bulb assemblies and switch.
Jesse-Infotainment
2021 F150
Driver side is on indefinite back order. I had to make mine. Plus you will have to run a wire to the BCM. From the driver kick panel to the BCM connector B
The passenger side was available when I got mine I ordered about 4 months ago.
I can give you part numbers Monday when I’m back in the office
also you’ll need to program the bcm
jj4567
United States
2022 F-150
When you say cargo light, are you referring to the LED Box lighting or something else?
Genoz
Eugene
2022 F-150 Lariat
Led box lighting. In 2022 the lariat led box lights are now part of a package I didn’t know about since I started ordering a 21 that came with those lights. The dealer updated the order to a 22.
Genoz
Eugene
2022 F-150 Lariat
I would definitely appreciate those part numbers.
Genoz
Eugene
2022 F-150 Lariat
Led cargo lights at both rear corners of the bed.
jj4567
United States
2022 F-150
I’m definitely interested to know if you are able to install the necessary parts & make the Ford OEM LED Box/cargo lights work on a ‘22 Lariat. I’m assuming - like me - your ‘22 F-150 does NOT have the Bed Utility package and, given that Ford does not currently offer an installation kit, you’re attempting a piece-by-piece install. Please let us know how it goes! Good luck.
Genoz
Eugene
2022 F-150 Lariat
You are right. I didn’t order the bed utility package. There are connectors at both corners of my frame that have dummy plugs installed. I believe this is where the pigtails would plug into.
jj4567
United States
2022 F-150
Jesse-Infotainment
2021 F150
ML3Z14A411F (Driver) Back ordered
ML3Z14A411D (Passenger)
Jesse-Infotainment
2021 F150
I don’t know anything.
Genoz
Eugene
2022 F-150 Lariat
No luck finding the “E”. According to the information I can find the -E is the correct pigtail for the driver side cargo bed light. It is on national back order.
