FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS)
tonesto7
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
On the Advanced Info page, under version SYNC4 v4.0.2181 the last updated shows "null" I thought it used to have the date 01/22/22. version 2022.03.27.0 Any meaning to this? Thx
Nothing to worry about it's merely info only and doesn't mean there are issues...
Mine is not returning any data for the date as well. Something is not populating on the ford side of things.
trojandawg3
Shannon
Northeast Georgia
2022 F150 XLT 302A FX4 SuperCrew 3.5 EB
Industrial Automation Specialist
Mine is missing the date also but shows version v4.0.21297. How does one know which version they should have?
ken325i
Ken
TN
2021 F150 King Ranch
Last week my dealer resolved the 1.7.1 Sync update failure. Now, Sync is updated and Auto Update is no longer grayed out.
Now, the Widget no longer shows the Sync version, and OTA Update data still shows the 1.7.1 failure. Is this correct? Will missing and incorrect information remain until a new and successful OTA update?
Sapphire
Chicago
2021 F-150 Powerboost Platinum
Thanks for that Wikipedia page on the revisions, @Bo15 .
My truck was built in Oct 2021, and is currently on 21223_PRODUCT Rev 197, which isn’t on the wiki page. Things work, so I’m not too concerned with the software version I have. I may not ask the service center to do anything with updates when I bring the truck in for the TRM and insulator recalls. Ford doesn’t seem to have things well-organized with firmware and may break things.
trojandawg3
Shannon
Northeast Georgia
I think nirvana is at Software Version: 22034_PRODUCT Revision: 364
S/W update versions
I'm confused on all the numbers...
Version 22034, Revision: 364, OTA 1.7.1?? Do they all mean the same thing?
Where do I find each of these numbers?
tonesto7
tonesto7
Anthony
Lol... I wouldn't bother trying to understand it because the OTA versions make no sense
trojandawg3
Shannon
Northeast Georgia
So just looked at my truck and it says Version 21297 Revision 253. It says no update available when I push check for updates. Should I have an update?
SonnyDigs
Sonny
FordPass Scriptable Widget v2022.02.18.0
Description:
Many months ago I found a FordPass widget while searching for some Ford pass API stuff.
I've completely refactored the entire script and turned it into an alternative control to FordPass.
Feature Walkthrough Video:
What's New in V2:
  • New Widget Designs
  • Define widget types in widget settings as a parameter (this allows you to have multiple versions of the same widget. If you don't define a color mode it will use the system dark mode setting.
    • detailed
    • detailedDark
    • detailedLight
    • simple
    • simpleDark
    • simpleLight
  • Quick action buttons on some of the widgets.
  • Modified the fuel/battery to embed the icon in the bar itself.
  • New dashboard app that opens in scriptable for info and controls
  • Push notifications for the following:
    • Widget updates
    • Deep Sleep Mode
    • Low 12V Battery (off by default)
    • Firmware Updates
  • Lots and lots of bug fixes.
Download and Instructions:
https://github.com/tonesto7/fordpass-scriptable
Ford Widget Tool Installer (tonesto7.github.io)
Updating from v1:
Please install the latest widget tool
Latest Release Announcement:
Reporting Issues and Feature Requests:
Please open up issues or feature requests here https://github.com/tonesto7/fordpass-scriptable/issues
If you are a coder yourself please submit pull requests and I will gladly merge them if they make sense.
Giving Thanks:
Thanks again to dschablowsky for all his work on the original script which gave me the ambition to make this beast of a widget.
Thank you...
Is it Android compatible?
Or a Android version?
abd79
Wayne
2021 F-150
Why every time I have a full tank of gas does it always read “- -“?
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 4340F318-06CC-4CA7-9B30-A57C3B4F6AE8
ziptbm
'22 MME GT & '22 F150 Lightning Lariat ER
@tonesto7 is this widget still working for you? It seems like Ford is purposely trying to make things difficult...
And on a slightly separate note, have you considered bringing any of this widget's data and functions into Home Assistant?
SmoothJ
New Jersey
2021 F150 HEV
This has not been working for a while now, and with Ford now temporarily blocking IDs, I didnt want to press my luck.
