RainorshinePNW
https://money.usnews.com/investing/...ecalls-2-900-ev-f-150-lightning-pickup-trucks
June 27, 2022
(Reuters) - Ford Motor Co said Monday it will recall about 2,900 F-150 Lightning trucks because a software issue may result in a failure to provide adequate warning of low tire pressure.
The recall is the first for the Ford electric pickup truck. Ford said the trucks tire pressure monitoring system light may not illuminate when intended and may not be able to provide adequate warning of low tire inflation pressure because the recommended tire cold inflation pressure value was incorrectly set to 35 psi rather than the correct inflation pressure of 42 psi.
The recall covers 2,666 U.S. vehicles and 220 in Canada. There are no accidents or injuries connected to the recall.
Ford said low tire inflation pressure may lead to poor vehicle handling and a possible loss of vehicle control, which could increase the risk of a crash. Dealers will update the Body Control Module software for undelivered vehicles and customers who want the remedy immediately, a fix that takes approximately 20 minutes.
Ford will also have the software update available through an over-the-air update in 30 days for all current customers.
June 27, 2022
