AZT9
AZT9
Peoria, AZ
Tried that. N
I would not reset your options, but I would try to reboot the center stack. Many commands go through there.
From page 515 of the manual:
You can reboot the center display using the controls on the steering wheel.
1. Simultaneously press and hold the seek forward and audio system power button for 10 seconds.
Tried that one. Didn’t work unfortunately
JPro
Vancouver, WA
22 F150 Lightning Lariat SR
Rebar Detailer/Estimator
I saw somewhere that there’sa manual frunk release where a traditional hood release would be under the driver side dash, a red loop looking pull
AZT9
AZT9
Peoria, AZ
Yup. Read that in the manual. You can hear it moving something but it has failed to release the secondary latch
JPro
Vancouver, WA
Ford F-150 Lightning FRUNK failure issue will not close or open w/ "Frunk Malfunction See Manual" message 5D9082AA-3575-4358-AF9E-5066704990B2
Crilly
Dale
Hartford wi
2 Mache GTpe
The manual release has to be pulled twice. Maybe with a helper pulling up.
AZT9
AZT9
Peoria, AZ
I’ve tried it. But won’t hurt to try again. Thanks
FordLightningMan
Upstate New York
F150
If it's so stuck, are you sure you can't drive it for now? Maybe do a spin around the parking lot before you head out, but it doesn't seem like the frunk is going anywhere?
AZT9
AZT9
Peoria, AZ
It’s pretty stuck on that secondary latch but with my luck thus far with the paint coming off on the grille now this, I can just picture that thing releasing at 70MPH on the freeway 🤮
  • Haha
Bigpoppa
Lightning
Strategist
Go old school and hook a bungee strap under it and strap it to the frame, then drive it home. At least you want have to worry about it flying open until the reinforcements arrive.
My gut tells me that if it isn't fully latched the truck won't even drive.
AZT9
AZT9
Peoria, AZ
When in doubt, Redneck fix FTW!
merek
Buffalo, NY
F150 Lightning Lariat ER [6/20]
They are a few weeks out for an undrivable vehicle? You could try another dealer, but you should at least be getting a loaner. I would push them to make room.
Bonus points if you ask for the mannequin as your loaner -- it's only fair.
p.s. I would not drive the vehicle any substantial distance, and would have it towed if the dealer is farther than like a mile.
