9onmy6
- Feb 9, 2023
- Greenbow, AL
- BMW M2, Ducati MTS 1260, 2023 SR Lightning XLT
- Occupation
- Housemaker/Veteran
Rear look.
Came with a little cover for that area, here's a picLooks great! Did the new front emblem have the cutout for the camera washer jet? If so, how'd you cover that?
Mine came with the cover as well, but I did not see a way to attach it. Did you just glue it on?Came with a little cover for that area, here's a pic
I had a dealership do it, but I talked to them about it and they said if it comes down to it, they would do thatMine came with the cover as well, but I did not see a way to attach it. Did you just glue it on?
Cannot wait till it is warm enough to put ceramic on my truck. Dang this weather.
Could you tell me where you got the plastic guys ? Thank YouGot my Frunk carpet! (no truck to put it in yet)
The plastic guys are velcro on the bottom. They do not move once set down.
They come with the mat.Could you tell me where you got the plastic guys ? Thank You
Direct from Ford:Could you tell me where you got the plastic guys ? Thank You
Nice! That's the one accessory I went back and forth on. My fear is it wouldn't lay flat and becomes annoying to access the cubby underneath. What are your thoughts?Direct from Ford:
https://accessories.ford.com/products/interior-frunk-cargo-area-protector-for-f-150-lightning-only
Was the perfect thing to use up my points...
It was mostly an impulse buy but so far it does a great job of keeping 12 packs from sliding about. It still has a couple of kinks in it from being rolled up for shipping but it seems to stay in place pretty well. Honestly I don't need to access the cubby very often so I doubt it will bother me. I do like the finished look it gives to the frunk.Nice! That's the one accessory I went back and forth on. My fear is it wouldn't lay flat and becomes annoying to access the cubby underneath. What are your thoughts?
I almost bought but their checkout process was very wonky. If you are using the 22,000 points that came with the truck, you should not pay $10 bucks. It did the same to me. It would ignore the promo code and say I owed. I finally figured out you have to go through the lefthand screen to choose the destination (dealer address) and keep hitting Continue, then apply promo code and checkout. Only then did it show the whole purchase (including TX 8.25% tax) was with points and had some left over. At that point my impulse died out so I cancelled. Some very poor web programming IMO.I wouldn't have used real money on it but after the 15% discount it cost me less than $10 with points.
