sotek2345
- First Name
- Tom
- Jun 7, 2021
- Upstate NY
- 2022 Lightning Lariat ER, 2021 Mach-e GT
- Occupation
- Engineering Manager
Something was very off with your route planning on the Lightning, unless you had to add a lot of miles because of charger availability. I do a ~500 mi each way trip with my Lighting every few months and it only added ~30 minutes compared to an ICE vehicle (assuming regular facility and meal stops).I get what your saying but when every competitor has it then it starts to become needed. I was just planning a trip today and it would’ve taken 6 hours in charging on route for my lightning vs only 1.5 hours on my buddies myp. Now I will concede the super charger network and efficiency makes up a good portion of the difference but didn’t change the fact that my truck turned an 11 hour drive into 17 and turning a 2 day trip into 3. If 350 chargers were available (not ford’s fault) and my truck accepted it I would drop to under 2 hours of charging for the 650 mile each way trip.
Also - 350kW chargers won't speed you up that much. You would save ~15 minutes per stop. Depending on spacing you would have 3 or 4 charging stops on a 650mi drive, so max savings of 1 hour.
