Tonneau covers don't boost mileage.I have made the round trip from my home to my ranch 3 times. It’s 202 miles round trip and here in Texas I run the AC full blast the whole way. Speed limits vary but my MO is to drive 5 mph over the limit. That means 70 for about ⅓ of the way, then 75 for the next ⅓ and finally 80 for the last leg. So average is 75. When I return home I have around 45 miles on the GOM. I have a tonneau cover which is supposed to be a mileage boost but I don’t have a comparison. There are some considerable hills en route which are definitely affecting the mileage. My best guess is 265 miles on level ground. My truck is an 2023 ER Lariat.
I don't think that average speed can be interpolated to performance at a particular speed. My experience has been that the difference between 75 and 85 MPH is associated with a 25-30% drop in range. Also your rate of acceleration at any point has a bigger effect than even that. One pedal-mash to blast past somebody can change a 200 mile trip at 2.2m/kwh into a 200 mile trip at 1.8m/kwh. (And that pedal is tempting)I have made the round trip from my home to my ranch 3 times. It’s 202 miles round trip and here in Texas I run the AC full blast the whole way. Speed limits vary but my MO is to drive 5 mph over the limit. That means 70 for about ⅓ of the way, then 75 for the next ⅓ and finally 80 for the last leg. So average is 75. When I return home I have around 45 miles on the GOM. I have a tonneau cover which is supposed to be a mileage boost but I don’t have a comparison. There are some considerable hills en route which are definitely affecting the mileage. My best guess is 265 miles on level ground. My truck is an 2023 ER Lariat.
If you use Ford's Navigation and put in the destination, it in fact DOES put in the elevation changes.Thanks everyone. You can probably guess I'm new at this EV thing. I have a Lariat ER. I'm going to try a round robin trip today I hope, from Mesa along Hiway 87 to Hiway 188 to Globe (fast charger there if I need a quick top up) then US 60 back to Mesa. Slightly over 200 miles. Starting at 90% charge, trip planner says I'll get home with 20%, but I don't think it takes into account the elevation changes on this trip.
If you send that trip to the truck, pull it up, and select Go, then the navigation will forecast your trip properly. I'd suggest you also use ABRP (A Better Route Planner), AND lookup every charging stop in PlugShare ahead of time AND day of trip.I used the trip planner in FordPass.
ABRP says you should be OK, it suggests you charge a bit in Globe, but based on the arrival %, it may not be neededThanks everyone. You can probably guess I'm new at this EV thing. I have a Lariat ER. I'm going to try a round robin trip today I hope, from Mesa along Hiway 87 to Hiway 188 to Globe (fast charger there if I need a quick top up) then US 60 back to Mesa. Slightly over 200 miles. Starting at 90% charge, trip planner says I'll get home with 20%, but I don't think it takes into account the elevation changes on this trip.
Thanks, I had planned to use both plugshare and ABRP.ABRP says you should be OK, it suggests you charge a bit in Globe, but based on the arrival %, it may not be needed
Be aware that if you plug it into the Ford Nav, it will be a bit pessimistic, but you should still be OK.
Make sure you use PlugShare during planning AND day of trip.Thanks, I had planned to use both plugshare and ABRP.
My experience with a F150 without a tonneau cover, and an F150 with one....I saw no difference.Tonneau covers don't boost mileage.
