Full Size Spare - No Pressure Sensor?
Calvin H-C
Calvin
Had a blowout on a tire and had it swapped with the full size spare, but found the spare does not register. Is there no sensor on it or is there a process needed to have the vehicle see the spare?
I'm guessing there is no sensor on the spare based on its rim being a a cheaper item. No five-tire rotation for this vehicle. ;)
There is no TPMS sensor in the spare, I would be surprised if you found ANY vehicle with one.
It is also a TEMPORARY spare, says so right on it.
Ford has never had TPMS sensors in the spare.
rdr854
Northern Virginia
I swapped my limited use spare for a full sized spare using a matching Lariat wheel. I also added a TPMS device so that I would have a fully functional spare. I have no plans for a 5 tire rotation. I will just replace the tire when it is 6 years old even if it has never been used.
Calvin H-C
Calvin H-C
Calvin
This all happened to my wife last night, and now in the light of day, I can see TEMPORARY on the tire.
Naturally, the dealership never made this clear, only saying it was a "real" tire and not a donut implying it was just like the rest. They also don't tell you the jack is not able to lift the vehicle, at least not safely. :confused:
Then there's the lousy roadside assistance, partly due to jurisdictional issues in our area, but took five hours our of her evening to get the tire swapped by another service that we now have to submit a $170 invoice to Ford for reimbursement. I'm wondering how many hours of my time that will cost.
We also intend to get the dealership to replace the tire as it only has 6300 km on it, and there was no "road hazard". Then there is this piece that needs fixing...
Ford F-150 Lightning Full Size Spare - No Pressure Sensor? 20230820_095329
Doesn't surprise me. The last time I saw a vehicle that had a spare that was the same as the rest and they recommended a 5-tire rotation, TPMS sensors probably hadn't been thought of yet. ;)
PAndaemonium
MY23 Ford Lightning XLT ER
Old thread,—but I had a flat, dropped off my wheel at a shop and ran my spare for a few days. All 4 sensors were reading and pressure was consistent with what I had on spare. Something change in MY23?
EdRudy
Ed
Springfield, VA
Mine has a TPMS sensor. I bought a full size Lightning Lariat wheel from a member of this forum and had the dealer install an OEM tire and sensor. Guess I need to add a jack to the list.
Because you added it...
