i'm thinking this problem is caused by Fordpass 4.30.2, months ago in an older version I tested reduced rates of charging and it worked and stuck to the reduced settings, now not so much.
Hit cancel, also turn off the mobile device wifi, use your cell connection.I try to connect my FCSP to FordPass and keep going round and round with these screens. It just keeps going back and forth between FordPass and CSP Setup apps.
I’ll try itHit cancel, also turn off the mobile device wifi, use your cell connection.
This is assuming the FCSP has bonded to your home wifi
Just to confirm because your profile just says Lightning. You do have an Extended Range battery right? And you didn’t buy a FCSP but it was sent to you for free. And your truck is a ‘22 or ’23?Anyone having issues with their unit not drawing the full 19kwh?
- I have a 100amp breaker
- 3awg wire
- unit dialled to “7” to draw the max 80amp
- app showing 80amp
Any suggestions why the truck is not drawing the full 19kwh? I max out at 10kwh…
Yep the Standard range can only charge at 11.3 kW max input. It has a single onboard charger. The 22 and 23 ER have a dual charger so can do 19.2 kW.Good questions. I only have a standard range 2023.
….I think I know where this is heading lol
Yep. SR has only the single onboard charger. 11 is the most you’ll ever see.Good questions. I only have a standard range 2023.
Good deal. For future help click here now:My hunch was correct. Appreciate the help.
@ccowboylightning - I see you changed your vehicle but I meant to only put Pro or XLT or Lariat, not all three! Choose one .Good deal. For future help click here now:
https://www.f150lightningforum.com/forum/account/account-details
and scroll down to Vehicles and change yours to 2023 (Pro/XLT/Lariat) SR F150 Lightning.
