WhipSticks
PSA: Anyone who drives an EV is familiar with the federal tax rebate on new or used EVs, but fewer might be aware that not only can you claim 30% of the cost of the EV charger you install, but you can also claim 30% of the labor costs involved in the installation. In general, any costs associated with the electrification of US households are qualified costs under the Inflation Reduction Act and related federal rebate programs. Last year, I had a heating system installed that placed significant loads on my electrical panel. My electrician determined that I had to increase my service level from 200A to 400A in order to safely run this system. That upgrade required hundreds of feet of trenching, conduit, and low-gauge wire to be run from the service pole on the road to the house. The trenching required that two large trees be removed. It required the power co install a new transformer (the labor costs of which I had to pay). It required a second panel to be installed inside the house, and labor costs associated with the wiring to the geothermal heat pump. It required inspections and fees be paid. All in, this was close to $30k worth of work. I was able to recover $10k of that in federal tax rebates last year.
If you buy a charger (say a FCSP) and have to pay an electrician to run wire from your basement to a 100A sub-panel in your garage to hook up your charger your total costs could run north of $3k. That is $1k that you can recover at tax time. Don't forget to keep you invoices for parts and labor!
