invertedspear
- Jan 18, 2023
- AZ, USA
- Website
- lightningcalcs.pages.dev
- Antimatter Blue XLT (312A) ER, 2004 Jeep TJ
I am not an electrician, so this question is coming from pure ignorance with a touch of mad scientist.
When I put a charger in the garage, I was planning on getting an SR, and honestly, was just going to use the mobile charger that was included at the time. But I also knew we were eventually going to be a 2 EV family, so when the Electrician ran the wire and installed the 14-50 outlet, I had him run 2 lines on independent 50 amp breakers.
Now I own an ER, and Jeep's EV Wrangler is pushed off to 2028, so I'm thinking I want to go ahead with the FCSP. The kicker is that the charger is 120 ft from the panel, so pulling all the existing copper out and running new lines is going to be expensive. The mad scientist in me says I should be able connect both of these 50 amp lines to a cutoff switch in the garage, then run a single line out of that to the FCSP and run it at 80 amps. In the main panel both lines are coming off breakers on the same rail, one right above the other. Would this work in such a way to not be a hazard? I would think that if one of the lines somehow became disconnected, the overdraw on the other line would trip that breaker and it would still fail safely.
Please tell me if this is a terrible idea or not, or if there's any other way to do this so that I don't have to pull out the existing copper and run a new line.
Thanks!
Thanks!
