Low / Medium Cost Audio upgrade
sstevetx
Steve
Help! What do you do with the plug from the original B&O subwoofer?
With my setup I didn't use it. The Keyloc uses side speakers input rather than the subwoofer to avoid the bass roll off
Storm Breaker
Norm
F-150 Lightning Lariat
truck driver
just installed the soundsgood audio fix the bass roll off kit. i kept the factory sub and added the kicker hideaway 10inch. WOW!!! with the right amp settings the bass really hits. im very pleased. in my younger years i had 2, 10 inch kicker comp VRs. so i am very familiar with nice sounding and feeling bass.
Storm Breaker
Norm
truck driver
ill be doing all the same upgrades as the OP too. i have all the equipment. just need to find time to install.
Storm Breaker
Norm
truck driver
i found the time. i installed and sound deadend the doors. i even replaced the center speaker. eveything sounds amazing. full volume and still crisp. perfect bass. *chefs kiss* Only problem was trying to mount the center speaker. it compressed fit right now. any info would be helpful. i know people just unplug it but with the proper set up it sounds really good.
this is the speaker.
https://www.amazon.com/Dayton-Audio...&qid=1713815177&sprefix=3.5+8o,aps,107&sr=8-5
https://www.amazon.com/Dayton-Audio-PS95-8-Source-Driver/dp/B00Q3M9852/ref=sr_1_5?crid=3CWW0IWGQ3JOI&dib=eyJ2IjoiMSJ9.5X00yFotYAw_BUOEvvJf1SP8eyWPNwPbkzTwQGQtstN4G-MdwkrNyeVnJyYF27969sM7YSazNXkwunqXukCA6D-dzBif1dNB0IwPX4pBNY7YXwcG_djZaq-Mz5G-vqhtgWa4vc9Z_d3BoKyzXoF77UC2t2Yl0DAqGmxK6O_eeIyucJeJOnokVDopok5WHM5xcVGYfJ68vbBpnkv3NJ2dx8vnwEppuohQAjBmojIr_v8.n8BzjvvebccahWXBJnnpc2wN3iAodSJEQubfIMEh8fA&dib_tag=se&keywords=3.5+8ohm+speaker&qid=1713815177&sprefix=3.5+8o,aps,107&sr=8-5
I have my dash speakers in my garage also waiting to find the time to install them. I looked up the spec of the speakers you got and the required mounting depth is almost 2" deep. That may be your issue.
Maineiac12
Iowa
Could this also be done to an XLT or Pro? I don’t have the center speaker or sub from the factory and I’m guessing the stock head unit isn’t as powerful
BennyTheBeaver
It's a different configuration, but yes. I've upgraded all speakers and subs in my Lightning.
Bokenator
Curtis
Georgia
2023 Lightning Lariat - Antimatter Blue. 2020 Hyundai Palisade Limited
Where did you mount the new Kicker Hideaway? Did you figure a way to keep it behind the seat, or did it make it out under the rear seats?
Storm Breaker
Norm
truck driver
I put it behind the rear passenger seat upright with velcro to kepp it from moving
ppmax5000
Colorado
2022 Chevy Bolt EUV; 2022 Ford Lightning Lariat ER Max Tow
I just bought a used, mint condition 2022 Lightning Lariat in Smoked Quartz Metallic and have been gathering parts lists for upgrades.
I dont know anything about speakers or brands anymore. It seems some go with Alpine or Focal or JL Audio. A set of JL Audio price out to be about $100 less vs the Alpine. Any advice our thoughts about which to buy?
Also, if I go with JL Audio 6x9 which mounting bracket do I need? Is that the Metra 82-5606?
So in the picture below, the 2 RCAs are for the powered sub...what are the 2 gray molex for? Do those plug into the amp? Or do I have to splice into the side speaker output coming from the amp?
Ford F-150 Lightning Low / Medium Cost Audio upgrade 1732660140329-3y
watts/up
2023 Lightning Pro
Regarding the KeyLoc, where is that image from? According to the manual the connector on the left is remote in and out, power, ground and stereo speaker level inputs. RCA on right go to an amp (or powered sub).
Ford F-150 Lightning Low / Medium Cost Audio upgrade 1732667340574-48
ppmax5000
Colorado
watts/up
2023 Lightning Pro
@ppmax5000 Just a quick follow-up since no one else has chimed in yet about your speaker question... I haven’t replaced my mine yet but I have done a fair amount of research and planning. From what I can tell the speaker brackets you mentioned should work but I can’t confirm from experience. I can say that they are used in this in installation.
Also, here’s one of my previous posts with some additional information:
https://www.f150lightningforum.com/...-advice-for-non-b-o-system.20815/#post-411047
