Is there a way to get the BED LIGHT to come on when you open the tailgate?
Evlar77
Evan
Port St. Lucie, FL
2024 Ford Lightning Flash
I've searched the manual and can't find this but it seems like a reasonable feature to have the bed light come on for a few minutes when you open the tailgate.
I always struggle to find the button in the dark.
CD4TNF
F150 Lightning ER
Zone Lighting in the infotainment to activate the light, then open the truck bed? That would be the only way I can think of.
Your idea makes too much sense.
Evlar77
Evlar77
Evan
Port St. Lucie, FL
Thanks I'll tinker with that but I still think that's a manual switching on/off. In the prior truck I've owned (Rivian), the bed light came on automatically when the tailgate opened - which is super helpful after dark.
CD4TNF
F150 Lightning ER
Yeah my suggestion is manual. Sorry. That's all we get.
I agree the zone light is useful after dark.
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
you could pull the push button switch and change it out for a motion detector if you have a tonneau cover. That would open whenever you open the tailgate.
Other option is to install an illuminated switch and then reseal. Shouldn't be that difficult.
Tom Jensen
Arlington, Virginia
F-150 Lightning 2023
Attorney
I think Ford should be a bit more aggressive in assuming how often we users are trying to do stuff in the dark. And at least some of us don't have the night vision we once had in bygone days. I agree that the bed light button should be illuminated when the headlights are on, and that the light itself should come on when the gate goes down. The button could be configured to turn the light off if the user doesn't want light. Similarly, I can't be the only person who has had to fumble around in the dark to find the button on the lip of the hood that closes the Frunk. It's got a black rubber cover that blends perfectly with the rest of the black rubber trim next to it. A light? Different color rubber?
djherron
Abbeville, SC
F150
Just go to Dollar store and get you a cheap stick-on motion detector light
Magendi
Philly area
Lightning Lariat
Leaving the below link for others who are electrically inclined as I’m not. Also tagging @ZSC100 who is and could possibly adapt it for lightnings.
https://www.f150gen14.com/forum/threads/bedlight-when-tailgate-opens-mod.18689/
That looks awesome, thanks for sharing. Sadly it is beyond my skills to pull off but I would definitely pay to have this enabled. I would use the bed lights so much more except for some reason I cannot succeed in building the muscle memory of where the switch is and end up fumbling in the dark trying to find it where they have it tucked in the place my hand is least likely to touch.
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2002 Jeep Wrangler
Mech Engineer
So my trick is I find the bubble light on the wall of the truck, and the button is just to the tailgate side of that. Locating the big light is easier than trying to find that button in the dark. And totally agree, a glow in the dark button like they have in the frunk would solve the issue.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Thanks for the mention, I know for a fact that our trucks (Pros and XLTs) do not have any method of knowing the tailgate is ajar. Which is stupid AF b/c it would've been so easy and cheap for ford to put a 1 dollar switch similar to the one installed in this thread but didn't. I do know from messing with the passive entry that trucks with the light bar tailgate have a Tailgate module, referred to as the RGTM - Rear Gate Trunk Module. I assume this module just handles the light, power, and passive entry of the tailgate, but also the Liftgate Ajar sensor/switch.
Ford F-150 Lightning Is there a way to get the BED LIGHT to come on when you open the tailgate? 1732681678509-k5
I guess this because the RGTM isn't even available for PID values in FORScan. You see the signal is available from the Gateway Module. So, sadly without adding the Tailgate module to the truck there isn't a way to get to do any action when it is open. I'm curious to know if anyone with a higher trim with lights and power tailgate has the functionality. When they open their tailgate manually does the bed light activate? If so whatever CAN message from the RGTM may be able to be injected to cause the behavior, but alas, it's more complicated than most care to mess with and not economical. :(
invertedspear
AZ, USA
lightningcalcs.pages.dev
My XLT does and it is annoying anytime I have the gate down for long loads. The difference is you had to option it with the power tailgate.
There are so many differences between the 311 and 312 option group I wish they weren't both badged XLT. I imagine there's a lot different between the Lariat 510/511 option groups as well. I like to say that we have the "XLT+" :)
