First charging using siblings tesla charger says error
SRP3
Sam
SW Engineer
I’m at my sisters house trying to use her Tesla charger with my adaptor.
Button on side of truck went blue but App says charging error.
Do I have to register my truck with her charger or something?
Or can I only use this with a supercharger?
Ford F-150 Lightning First charging using siblings tesla charger says error 1732813791436-e
luebri
Neenah, WI
Assuming you are referring to a Level 3 DCFC adapter which then only will work on Level 3 (superchargers).
AC Level 1/2 requires different adapter. There are several on the market. I use a Tesla Tap.
mrau
23 Lariat⚡ER
Post a picture of the adapter you are using. It may not be the right type.
This adaptor will only work for DC charging. If this is what you are using, it won't work.
Ford F-150 Lightning First charging using siblings tesla charger says error q=tbn:ANd9GcQ2BsjzVZapl_Sh6BSR0YeKFO1tjgvXjuK9sw&s
tls
New York
2022 Lightning
If the Tesla home charger (High Power Wall Connector) is old enough (1st generation) it won't charge our trucks at all. Not many of those left out there though.
Supercharger adapter works at Superchargers...
If you need an adapter for your Tesla home charger, A2Z’s Stellar adapter is very good and priced right - $108 ($99.90 with code FORDFORUM). https://a2zevshop.com/collections/charging-adapters/products/a2z-stellar-plug?ref=Typhoon
2022 Lightning
TeslaTap is the #1 adapter and the only adapter made in the USA.
The other adapters available are made in China.
The correct TeslaTap for a Ford Lightning is available at TeslaTap MINI - Lightning Version
Shawnson
Edmonton
Lightning Lartiat ER, Model 3 LR, Crosstrek… hehe
Developer
If its a wall charger, there is a setting it the backend software to only accept Teslas for charging, youn have to turn this setting off. She needs to go on to the wireless network of the charger then to the IP address to get into the backend configuration and change the setting.
Shawnson
Edmonton
Developer
The setting exists for level 2 stations deployed in public. You can even lock them down to certain vehicle as you can have them sitting in a public area but only allow people you want to use them. (Or stop weirdos from pulling up to your driveway and charging lol)
tls
New York
2022 Lightning
I had a very expensive TeslaTap fail from water infiltration, just like the QC corded adapters and the cheap Chinese Hansshow adapters. I also was not impressed at all by the way TeslaTap actively marketed their 80A adapter for other vehicles with 80A onboard chargers, then turned around and started marketing a "Lightning" adapter at a nontrivial markup, with some dubious rationale about continuous current draw and heating, a little while after the first Lightning trucks shipped. it's a much better quality product than the generic Amazon junk or the Hansshow which is clearly made to look just like the TeslaTap but is much worse, but the A2Z adapter seems, to me, to be the best on the market in terms of build quality, watertightness, heat dissipation, and cost, and I prefer it to the TeslaTap at this point.
2022 Lightning
The A2Z NACS-J1772 adapter is just a Chinese adapter with their name on it.
GUWIEYG NACS to J1772 Adapter Fit for Tesla Charger 80A Max Compatible for Tesla To J1772 Adapter EV Charger Adapter - AliExpress 34
Maxx
KrazyEd
Ed
Las Vegas, Nevada
2021 MME RWD SB, 2018 Zero FXS, 2014 Zero S
Taxi Driver
I have an early 50 amp Tesla tap and another
brand. The Tesla tap works on most destination
chargers that aren't internally locked. The other
one is hit or miss. Doesn't work on a lot of ones
that the Tesla tap does. I have used the Ford
DCFC adapter with my Lightning and several
unmodified Bolts.
