Android version has arrived with similar features as the iOS version.
No widgets, but my wear OS app still works fine on my Watch4Widgets? I just finished lunch break, will have to check later.
downloaded. haven't been paying attention to IOS updates. what's new here?
Thanks!
I'm note sure why that is the case.Strange. When I look up the app into on Play Store, I don't have bullet point #1 - maintain service records. The app version to be installed is 5.9
I'm on a Pixel 7 Pro on Android 15. My download size is only 20.01MB.
Any ideas why there'd be a discrepancy?
I seen this when I have a departure time set and not having the truck plugged in. If I hit climate control or fan button I get a error. Turning off departure time the climate control works just fine....very silly buggy software glitch.Departure time start of cabin climate, was wonky this morning, I watched the Vehicle screen show the message "starting climate" for several seconds as usual, then the screen flashed quickly and returned to the parked message instead of saying "Climate On Until x:xx...."
I hit other tabs to cause a screen refresh, didn't cause an update.
I hit the fan icon again, it went through the motions of climate start, then an error, then showed me that it was running with an ending time, for kick's I hit the add time button, came back with error that maximum time already alloted.
I'm guessing the automatic departure start actually worked, I was just not aware of it and the second tap on the fan caused an extension? normally that would "stop" the process ?!?
I can't say this is a glitch exclusive to 5.9.0, I seem to recall this inconsistency on prior versions.
Update, I received this today (12/11/24 @ 1:15 M.S.T.)Thanks for the info. I just checked, and it's not yet available to me, but I will keep checking.
