First year owner has battery question for winter
<nerd mode>
Actually, wetter air is less dense than drier air (see below), but having blobs of liquid water falling through said air is another matter!
I suspect that water on the road substantially increases rolling resistance as the tires have to push that water out of the way in order to move, adding to the range loss.
Source: The Engineering ToolBox (2004). Moist Air - Density vs. Water Content and Temperature.
Available at: https://www.engineeringtoolbox.com/density-air-d_680.html
</nerd mode>
I too was surprised by the way rain reduced the range of our Mach-E on one of our first road trips.
“Wetter air” is ambiguous. You are 100% correct regarding density vs relative humidity, but if by “wetter air” he means precipitation, the combination of liquid and gas will likely (depending on liquid/gas ratio) be effectively denser and negatively impact range.
mb0220
Matt
2022 Lariat ER
All I really meant was that when it's raining you get reduced efficiency (all other things being equal). But I can appreciate the scientific exhibition!
Mach Turtle
Central California
2021 Mach E, 2024 XLT
Bum
I think we've arrived at a consensus about rain and range. A question: How about snow and range? The effect of cold air is obvious, but what about the solid water? I haven't driven a Lightning in snow, but our Mach-E didn't seem to see much difference between rain and snow...except that slushy stuff got all over the front bumper and blocked the CCM radar, causing adaptive cruise control to fail until we descended to warmer air and the slush melted.
SunMar10
United States of America
2023 F-150 Lightning XLT Extended Range
artist
Preconditioning of the battery will only work if you have a departure time set and you're plugged into a charger.
Do I understand that starting (Fordpass app “fan” icon button) while plugged-in to the charger will only prepare cabin temperature but will not precondition the battery?
Correct.
To condition your HV battery, you must schedule a departure time, keep truck plugged in and energy be available from the EVSE for the 1-2 hours prior to intended departure time.
I mention this for EVSE which have independent time / energy restrictions for TOU compliance, this could complicate the conditioning process depending on time frame conflicts.
SunMar10
artist
Correct.
Hi TaxmanHog,
Thank you for clarifying.​
Hi Ford Motor Company,
If I regularly commuted then making a schedule of departure times would be “value added”; but, I don’t regularly depart any day or any time. It’s a lot of FordPass app tedium to “schedule” to depart 30 minutes from “now” to go out and about.​
It would be great if FordPass had a button to start conditioning cabin AND preconditioning battery starting “now”, and get a notification when it’s “ready for departure”.​
Scorpio3d
SS/IBA car wash owner
Hi TaxmanHog,
Trying to be helpful, if you include the @ And start typing who you want to include for instance @tax It should pop up with the user And then you can include them, and it will notify them that they have been tagged in a post. Hope that makes sense and helps!
F-150 Lightning Lariat ER
