ECG-24.2.5.6.3 | Software Update Experience (Gateway Module)
Zed
Chuck
2022 Lightning Platinum Rapid Red
This installed successfully on my truck yesterday while on a short road trip. First update since 9/6/24.
Mike G
N. AL, USA
I got the survey. No idea if I got the update though. Lol.
Hope this fixes my rattling interior and shrunken 360 view.
With regard to the 360 view issue. If your IPMA update was applied by a tech and you have the shrunken 360 view then the tech didn't follow the instructions. See page 3 of the attached.
luebri
luebri
Neenah, WI
Does anyone have a picture of what the correct vs shrunken 360 camera looks like. I have the CSP schedule to be done in a few weeks and want to double check its correct before I leave.
Ffxdude
22 Lightning Lariat ER
Came here to post the same issue. Never had problems with the 12v, when I checked yesterday with a vlinker it was at 89%.
Still the same for me, not sure what the issue is. Guess I'll ask the dealer when they call me back to reschedule the truck to get in and fix the shrunken 360.
Mike G
N. AL, USA
This can also be fixed using FORSCAN. Takes about 2 minutes, if you want to go that route. But back to my point, if the tech follows the TSB it shouldn't be necessary. They just need to run the APIM 360 View Configuration tool after updating the IPMA and everything will work out fine.
Reading...it's fundamental.
luebri
luebri
Neenah, WI
Incompetence.... its persistent and frequent.
I appreciate the heads up, and I will make sure I remind and double check their work!
queuewho
Western PA
F150 Lightning Lariat SR
I've got a 2-hr drive later maybe it will install overnight
