richguy82
Richard
2023 Ford Lightning Lariat
If it is available in the "easy" mode, go to the BCM module in the easy option, and use the search box on the top of the forscan window (search for "window") and see what pops up, or scroll through the available easy settings. If it's available, it'll be in there.
Or try the "difficult" way and make a backup of current configuration and change the lines in the "As-Built" section according to post #1.
Thanks all
Thanks all
The "hard" way shows 8 lines needs changing, so there will need to be 8 easy modes. For example, there will be 3 in BCM, 2 each in both DDM and PDM and one APIM.
See this post.
richguy82
Richard
See this post.
I was using that post actually. In BCM it’s not clear which 3 need to be changed. It’s pretty obvious with the other modules. I’ll just do it in “As Built”. NBD. 🙏
Maybe some day, someone (not me) will come up with a true easy mode that has one checkbox that handles all the discrete modules.
If you’re curious after you do As-Built, you can go back to easy mode and see what changed. From what I’ve noticed, they are linked so changing a value with one method gets reflected in the other method. If you do let me know and I’ll update post 1 with an easy mode option.
21st Century Truck
Martin
AFAIK, the "Easy Mode" is just a script that captures the discrete steps of the "Hard Mode".
In other words, the primary value of ForScan programmers' work is reverse-decoding the discrete settings in each separate module, and in some cases reverse-decoding the dependencies between several modules to modify the single or multi-module technical function... this results in the "Hard Mode" line-by-line parameter change instructions, and is the true value of ForScan for users like us.
The next, more easy-to-do but less critical programming action is to write a script, aka. "Easy Mode" which captures these discrete line changes into one-click execution of the desired modification.
In my opinion, this is why there are far more Hard Mode modifications available than Easy Mode modifications. Script generation for Easy Mode must sequentially follow the reverse-engineering discoveries that result in Hard Mode mods, and frankly seems less important for ForScan's value-based success in the past 10+ years.
I hope my write-up here makes sense and can be a useful way to see the programming effort that we all find beneficial.
richguy82
Richard
For anyone curious about Global Windows without “As Built”, I went ahead and did a quick pic before and after on the BCM. Just three quick changes from “Disabled” for my truck. The other 3 modules are obvious as they just say “Global Windows” Up and Down.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 IMG_4756
