I’m not sure why the truck still starts. Possible LVB issue?
Biologyinsight
2024 Lightning Flash
Educator
I received a warning message that a front sensor was not working and may need service. Message never reappeared and truck operates normally. Read on the forums that a low charge on the 12 volt can causes strange error message so I pulled out my multimeter to take a look. Could not get a steady reading from the meter(meter works fine it’s a Fluke). It would jump between 7, 8 and zero volts. AGM is new to me. Should I look onto having the battery replaced? It’s a 2024 Flash. Three months old.
How were you taking the measurement? Even a bad battery won’t jump around like that.
