Roadmaster Active Suspension squeak
Jcartwr97
James
East Moline, IL
2021 F150 Lariat Powerboost
Technology Consulting
Installed the RAS HD kit on my 21 PB to help with sag when towing my TT. RAS improved the ride tremendously both towing and unloaded, but there is a horrible squeak on the drivers side rear now. Anyone have any experience with this setup and had any similar issues?
https://activesuspension.com/
John_C
2021 F150 XLT 302A PowerBoost
I'm running the same kit on my long bed powerboost, and it's been flawless. No noises, and it's a game changer for me. How did you set yours up? I went with the 3rd hole, and both the white and black spacer (3 mm). It did lift the truck up a good 1½"-2", but my bed is normally loaded down daily so no worries there.
Jcartwr97
James
East Moline, IL
The instructions didn’t mention using different holes. What difference does the third hole versus the end one make?
John_C
It changes the location of the pivot to closer to the center of the leaf. Think of lifting a gallon of milk with your arms extended all the way, then doing it again with your arms closer to your body. Not at all a scientific explanation, but hopefully easy enough to understand.
Jcartwr97
James
East Moline, IL
Makes sense. I think I’m going to reinstall tomorrow and move to the third hole. Figured out my squeak issue, apparently I messed up the auto leveling sensor for the headlights somehow when I installed the RAS. Going to see if I can fix it while I have it apart tomorrow, otherwise I’ll have to replace it.
Jcartwr97
James
East Moline, IL
Reinstalled the RAS with the third hole and tweaked the leveling sensor and all is good now. Thanks for the suggestion.
emsmedic31
Matt
Milan, Tn
2021 F-150 XLT SCREW Sport 4x4 Rapid Red
If I add this to my truck, will it for sure raise the back end while unloaded? I’ve leveled my truck so I don’t want to add this and it raise the rear when not hooked to a trailer
John_C
Most likely, yes. Maybe not if you go regular kit instead of HD, and only go with the 1 mm spacing.
petervenkman
ohio
'21 Lariat Powerboost
can you elaborate? i am getting squeaking from mine as well. ras hd on 21 powerboost lariat.
also, i’m 99% positive road master says not to install on third hole for 21s.
did you fix your squeaking? if so, how?
ryanc111
Ryan
Bozeman, MT
Leadfoot Powerboost
I just installed this on my Powerboost this past weekend. Used the second hole from the bottom - seemed to be the best compromise for the headlight bracket - both on the inside hitting the bracket and center hitting the adjustment nut of the RAS. I also installed the RAS so the longer part of the bolts/nuts were on the outside. As near as I can tell I haven’t had any interference nor have I had any squeaks.
**edit - I haven’t put any heavy loads on it yet but still don’t think it would hit anywhere.
Bullet150
CO
3.5L F150 Lariat
RAS Standard raised my 145 WB EB 1 1/2” with only a Diamondback SE bed cover and maybe 20# of stuff in bed. Installed in first (longest) hole.
