Have 27 ft., 6,600 lb. (dry weight) Camper, need truck--which one?
cghall77
Whitby, Canada
F150
EV is just not a feasible option for many of us with travel trailers. If you are just a weekend warrior, travel a couple hours to your site that is one thing. For us, we like to hit the road and depending on our adventure, we are no stranger to spending 24hrs in the vehicle with a few 10 minute breaks for full up and stretching the old legs. Our annual trips, Toronto to Tampa area, not a chance I am stopping every hour to charge the vehicle. No doubt the lightning will fit the needs for 80% of the population, just not those that like to hit the road. As technology improves, I'm willing to buy into the EV trend but I need to see like 500km towing range and a 5 minute charge time.
Whiskey
Michael
Hesperus, Colorado
2021 F-150 Hybrid, 2020 Toyota Corolla Hybrid
Retired Miner
What trim level do you have? I don't know how you can get that payload on a PowerBoost, I would have to see that door jam sticker. The only PB capable of that payload is a 2021 XL PowerBoost with 6.6 bed and ZERO options added to the truck. If that's you, great, but please don't use that chart to determine payload of YOUR truck. That number is the absolute best payload possible on the lowest trim truck with no options.
For example, my Lariat 502a PowerBoost payload is 1400, NOT the 1830 on that chart, because my truck is a higher trim and has options added. You need to go by the door sticker, not the advertising material that very clearly says maximum payload, not standard.
Thanks I’ll go check now.
Whiskey
Michael
Hesperus, Colorado
Retired Miner
M
My XLT weighs in at 4,465lbs, stickers says GVWR 7,350lbs. I don’t see why the XLT isn’t rated for 2120 payload? Something with selection of tires maybe?
F150Eh
Canada, Prairies
2021 F150 XLT
M
Check out the Tire and Loading sticker (also in the door jam). This will have the max payload amount for your vehicle. Here's a sample.
Ford F-150 Lightning Have 27 ft., 6,600 lb. (dry weight) Camper, need truck--which one? 20210513_102625
Mengel
Houston
2021 power boost
Superintendent
I have the platinum power boost my payload sticker says 1600 and some change. I’m looking to buy at 27’ trailer with gwcr 7800 trailer. I rented a travel trailer last week and only got 7-9 mpg. Honestly I drove way to fast up to 80. Did some research and should have stayed around 60-65. Also heard best gas mileage is at the 7th gear so next time I will try it again and hope to get better gas mileage while towing.
mustanga10
Wisconsin
2021 F150 Lariat FX4 Sport 2015 Subaru Outback
Public Service/Government
I have a very similar size and weight travel trailer and chose to go with the 3.5 EB for the very fact that the torque come on at much lower rpms. Rpms that you will actually be running in while pulling. This makes the power of the EB much more usable than the 5.0 when towing. I so far have only about 400 miles towing my trailer with my new truck but it has not disappointed.
Osky
Kansas City
F 150 Lariat
Which axle ratio did you go with?
mustanga10
Wisconsin
I have the 3.55, the 3.73 was not available with the 3.5eb and max tow when my truck was produced. (Might be now, not sure.) It did great. On my last trip I had a heavy head wind and it seemed to like 7th and 8th gear with the occasional 6th gear for up hill climbs at 70mph.
DaHealey
Seattle
Toyota Tacoma
Mustanga10, Are you towing in flat areas?
I’ve found my Tacoma gets great reviews from people in flat areas, but where I I’ve (Seattle), it’s a disaster. Just can’t tow my 3k trailer, even tho well rated.
I’m also looking at a 8k GVWR trailer and starting to wonder if my 3/15 never-ending-build will be able to tow it.
cghall77
Whitby, Canada
F150
I ordered the start of March with the max tow / 3.5eco and only the 3.55 was available. I would have had to go with the 5L to get the 3.73. Again, things may behave changed since then and it may be determined by other factors as well.
mustanga10
Wisconsin
No not flat, not mountains but large hills yes, plenty.
