Administrator
Administrator
Staff member
Purple State
F-150
Admin
2022 Ford F-150 Lightning First Ride: This Electric Truck Impresses
Alisa Priddle May 20, 2021
Ford F-150 Lightning MT: F-150 Lightning First Ride Impresses 2022-Ford-F-150-Lightning-electric-prototype-testing-1
Ford was the quiet one—excuse the pun—in the electric full-size pickup truck wars. While General Motors created serious buzz with the return of the Hummer name on a GMC-badged pickup, and Rivian has had people salivating for the 2021 Rivian R1T electric pickup that comes out soon, there were crickets from the Blue Oval's Glass House HQ in Dearborn, Michigan. And what more can we say about the Tesla Cybertruck? Just look at it. Even though the Ford F-150 has been the best-selling truck for 44 years running, Ford took the longest time to even confirm it was working on an electric F-150, let alone release details. Heck, even the name—Lightning—was just revealed.
But now that it is time to toot its horn, Ford honks loudly. We have not only seen the 2022 Ford F-150 Lightning, but MotorTrend was among the first to get a ride in some prototypes; only President Joe Biden has us beat, after having somehow negotiated a spin behind the wheel.
Some of the trucks had material covering portions of the interior because surfaces are not final. Engineering-wise, these early-build trucks are still being fine-tuned, with systems in the calibration phase. But Ford assured us the drive experience is close to what customers can expect when the 2022 Ford F-150 Lighting goes on sale in May 2022.
Sounds of Silence in a 2022 Ford F-150 Lightning
One of the first thing Lightning drivers will notice is … silence. Even the test engineers said the absence of engine rumble is hard to get used to and it is easy to forget whether the truck is on or off. Regulations demand some form of sound to alert pedestrians. Everyone is inventing their own noise right now; some are futuristic whines like the Jetsons, others are deliberately aggressive. For the Lightning, Ford went for a white noise that is noticeable without being annoying.
We took our ride at Ford's Michigan Proving Grounds in Romeo, where conventional F-trucks undergo testing before they are signed off on. The Lightning underwent the same brutal rigors and had to meet the same requirements as the rest—no exceptions. By the time the Lightning goes on sale next year, it will have accrued millions of test miles.
First Ride: High-Speed Oval
Our first leg was on Ford's highspeed oval. From the passenger seat, the ride was quiet and smooth. When chief engineer Linda Zhang floored it from rest, the acceleration threw us back courtesy of the 563 horsepower and 775 lb-ft of torque from dual motors fed by the bigger extended-range battery.
Ford had said the Lightning can accelerate from 0-60 mph in the mid-four-second range, but President Biden teased out a more accurate figure while visiting Dearborn on Tuesday for a plant visit. "This sucker's quick," Biden told reporters. We agree. Equally impressive is the instantly available torque at highway speeds for passing, as well as the quick steering response to make that pass.
Being electric, the Lighting offers one-pedal driving—lifting off the accelerator slows the truck using the motors' resistance—and the driver can choose whether this function is on or off. It recaptures energy while decelerating faster to avoid stomping on the brake. There was no jerkiness detected as the setup slowed the roughly 6,500-pound truck. Even though it is about 1,000 pounds heavier than a comparable crew-cab F-150 with the 5.5-foot bed and 3.5-liter engine, the truck doesn't feel like it carries the extra weight.
The new Lightning is the first F-150 to utilize an independent rear suspension for more controlled handling while making room down the vehicle centerline for the batteries and rear drive motor. Situating the batteries between the ladder frame's rails extending from the front motor to the rear motor lowers the center of gravity, which further contributes to the Lightning's tidy handling and instantaneous steering response.
Switching to Sport mode provides more aggressive pedal mapping and sportier, more responsive steering, Zhang told us. We wish we were behind the wheel to verify. The Lightning has three other drive modes: Normal, Tow-Haul, and Off-Road.
Towing With All That Torque
The Lightning has a payload of 2,000 pounds and can tow up to 10,000 pounds with the extended-range battery and Maximum Trailer Tow Package (that drops to 7,000 pounds with the standard battery). For context, the max towing weight in a conventional F-150 is 14,000 pounds.
The truck we rode in was towing 6,000 pounds but it was hard to tell a trailer was attached. We could feel a slight tug, but it was explained as trailer lash, not an issue with the truck's capability. And with the independent rear suspension, you don't feel the pitch and bounce you can get when towing with conventional F-150s.
We went up a 25-percent grade, then down a 14-percent grade, and back up a 7-percenter. It is odd to not hear an engine revving, though on the downhills the motors generated electricity to replenish the battery. Tow-Haul mode does not increase the level of regeneration going downhill but it does tune it to keep the speed nice and steady—the EV version of engine braking.
The 2022 Ford F-150 Lightning's driving range drops when towing, but the truck's trip-planning apps can map the route ahead of time and track the truck to the nearest charge station. The truck knows when you are towing and adjusts the estimated range accordingly.
Like the rest of the F-150 lineup, the 2022 F-150 Lightning has Pro Trailer Backup Assist. Debuting on the Lightning is Pro Trailer Hitch Assist, which controls steering, throttle, and brake inputs to align the ball hitch under the trailer coupler. You have to hop out to attach the trailer yourself. Eventually regular F-150s will get this feature as well.
Off-Roading With a Massive Battery Pack
Ford fully expects Lighting buyers to take the truck off-road. The batteries are in a waterproof casing and there is a protective exoskeleton as well as underbody metal skid plates to protect them.
Ground clearance is a bit less than a conventional F-150's because of the low skateboard and its battery placement but is still a decent eight to nine inches, depending on the tire package. The truck we rode in had mostly FX4 trim bits, said Anthony Magagnoli, a Ford off-road and trailer-tow experience development engineer. All-terrain tires are standard; the Lightning has the same electronically locking rear differential as the combustion-engine model, and AWD courtesy of the dual motors.
While the regular FX4 has three off-road drive modes, they are packaged into a single off-road mode for the Lightning. With so much instantaneous torque available, softening the pedal map in Off-Road provides more control to allow a little bit of slip without outright spinning the tires. One pedal driving is not used off-road, as it's a surefire way to get stuck if you back off the throttle, lose momentum, and stop.
Traction and stability control are tuned for off-road. Cameras provide a 360-degree view, but there are none on the underside for off-roading to see the terrain below you when wheels are in the air.
But Can the Lightning Jump?
On our ride, the 2022 Ford F-150 Lightning performed like a giant rally car on a hardpacked bumpy surface. It felt more solid than the Ford Raptor, which was made for this type of terrain but was engineered to handle big movements and which can feel skittery in the relatively small stuff. "Tradeoffs," Magagnoli said. The Raptor, though, is good for jumping. "You're probably not going to jump this one, right?" he said. That garnered a good laugh, but it also made us curious.
The Lightning is robust enough to take some hits. During an off-road test we introduced the underbody to the ground, and it wasn't just a glancing blow. We hit some moguls where the vehicle's weight sat on the protective underbody. We cringed, Magagnoli laughed. The truck did what it was designed to do; with plates running from front to back, the pickup can almost surf over obstacles like the mogul we crested. Deep ruts, mud, and water also did not phase the Lightning.
Being electric does not give the Lightning a hall pass in any of Ford's testing requirements. When it comes to off-roading, being a EV can be an asset. The chassis does not have a massive engine hanging over the front axle and trying to roll over the tires. The center of gravity is lower. The independent rear suspension allows the tires to articulate on their own, delivering a smoother ride that doesn't toss occupants around as much. And the instantaneous torque adds a significant fun factor off-road.
Our brief time in the passenger seat suggested the 2022 Ford F-150 Lightning does not come with dynamic compromises that will upset loyal truck buyers. It is quicker, more responsive, and can tow and off-road as well as or better than comparable F-150s with combustion engines. And it has some perks from being electric that enhance the experience.
Then there is the more incorporeal: When you roll down the windows and hear birds chirping, leaves rustling, and no engine running, "I kind of feel like this is the right way to do this," Magagnoli said. "It feels more at one with nature."
SPECIFICATIONS2022 Ford F-150 Lightning
BASE PRICE$41,669
LAYOUTFront- and rear-motor AWD, 5-pass, 4-door truck
MOTORS426-563-hp/775-lb-ft AC permanent-magnet electric
F-150 Prius
Adam
Silicon Valley
2021 F-150 Platinum PowerBoost FX-4 6½
Software Algorithms
I wonder what the Lariat will cost. I am sure the Platinum will be to expensive for me.
The $41,669 starting price has all the usual asterisks – we can assume only the plush trim levels will arrive first and this is a price to tease the competitors.
I'm guessing first deliveries will be Platinum $80K neighborhood, then a bigger battery option becomes available in a tow-vehicle specific trim maybe with faster charging option, then a performance option, etc.
Fleet and van bodies, emergency and law all make sense – fixed routes, known battery demand … I think Rivian and Ford are going to be rewriting the rules on fleet sales. I don't see why Ford would do less – they've made so much from their gamble on the Hybrid, the executives must be aiming very high and wide with the Lightning.
I think Ford is making batteries with SK and presumably will work out its own chip supply side, too. Hopefully before real production, Ford will up the range calculations with a press announcement like "we've improved our battery technology, range is up 20%." That said, I've had two Model X's and for 90% of the time, range is no issue, and when it is, there's the F-150.
The things I didn't see in the reveal were the gimmicks and gadgets … rear steering (GM) or tank steering (Rivian) or the wild off-road suspension (Hummer) … Ford is staying in the EV pickup lane and leaving respectful room for Raptor and other sub-brands to ask the customer "how much do you want to spend?" I think this is great. I would have been disappointed to see the F-150 show up looking like a space oddity or over the top Hummer.
I've seen the Rivian up close and it's much, much smaller than my '21 F-150 FX4 … Rivian is competing with Range Rover and Model X. I don't see a lot of people cross-shopping (and the prices are far apart.) Rivian's also not building a work pickup, they're building the adventure and weekender markets. With this price and equipment, the Lightning is the most exciting work truck and who would want to buy a gas guzzler if you don't need more range than the Lightning?
I've had a Tesla X since early 2016 and I know all there is to know about distance driving and towing … it's not good … it's a helluva lot of time sitting in a Supercharger. Ford and all the EV pickup competitors will have to solve the range problem before I sell my F-150 Prius … : )
Still, I'm impressed by that price number, even if it is a jab at Tesla and Rivian. If the F-150 Hybrid is the closest relative model, it's cheapest config is an XLT Supercrew at $43,485 so Ford is saying it's cheaper to build the new truck, even with so much new and unknown, including independent suspension, etc.
Munro explained EV costs in his tear downs – much cheaper to build (like 30% +/-) because of simpler parts, cheaper parts, fewer parts, quicker down the assembly line, less to factor into cost of warranty, etc. Tesla goes one further with slab panels and little or no paint. We'll see how well that plays out once the initial "gotta have it, first kid on the block" evaporates. I put a deposit on one, but I think like most people, it's $100 that I expect to be refunded when I come to my senses and realize I wouldn't be seen dead in that ostentatious billionaire's experiment in brand marketing.
Squatch
Miami
Reef flip flops
" One pedal driving is not used off-road, as it's a surefire way to get stuck if you back off the throttle, lose momentum, and stop. "
Interesting. Ford is touting one pedal driving as the great equalizer of newbs and pros off-road with the 2021-ish Bronco.
Pedaldude
Arizona
...put a deposit on one, but I think like most people, it's $100 that I expect to be refunded when I come to my senses and realize I wouldn't be seen dead in that ostentatious billionaire's experiment in brand marketing.
Ford F-150 Lightning MT: F-150 Lightning First Ride Impresses AA850F65-5632-4084-A717-AC049844CF8A
One of my first jobs was at a garage that specialized in European cars, I worked there hoping to learn about working on cars but 90% of the time I was driving them around. Two customers had Lotus Esprit turbos and they had to pass emissions every year and with the carburetors it was tough. The two cars shared a secret carb kit that would be installed only to pass emissions and the cars ran like crap with them. Even then, the cars would fail if they weren't warmed up enough but they would also overheat if they were run for too long because they were so leaned out. So to pass the emissions, the only way was to take them on the highway for a few miles driving 80mph in third or fourth gear and then get off the highway and through town and into the emissions testing shop, which would be warned in advance because if the car idled too long it would fail. So if I missed a traffic light, was blocked from getting into the garage for emissions by a parts delivery driver who blocked the garage door or even getting stuck behind a truck or slow driver. I would have to shut off the car, let it cool down and start the process over again. Once it took me three tries and all morning but usually I could get it done the first time. Long story short, I always was a fan of the Esprit and Colin Chapman was a hero of mine. Despite that, I hated the Esprit and dreaded driving them. Because of the angle of the windshield and seats, you couldn't see shit out of them! Imagine trying to park your truck with the seats reclined all the way and I am not short, my head didn't hit the roof like in some sports cars but it was close. The A-pillars were hard to see around and you had to bob you head to make sure you could turn safely in traffic. One of the garage owners almost got hit head on by a septic truck with me in the passenger seat while turning left at a light because the blind spot is that big! I feared that whenever I saw an Esprit, that it would need an emissions sticker. Driving them was truly awful compared with say a 911, which has excellent visibility and seating position.
I really hope that I don't encounter too many soccer moms and golf grannies driving around Cybertrucks, they're bad enough when in the Tesla sedans.
