Knickell
Kyle
Mazda Protege, Ford F-150
The 2021 F-150s equipped with the Sport Appearance Package and the "18" 6-Spoke Machined Aluminum Wheels with Gloss Black Painted Pockets" available on the XLT and Lariat trims will supposedly be wearing Goodyear Wranglers with unique outside white lettering from the factory.
If you're like me, one of my favorite features of the Sport Appearance package is the stock wheels, and the OWL tires!
I have looked at multiple different tire retailers to do more research on the OEM tire for the XLT and Lariat Sport packages, but couldn't find a whole lot for the exact tire the truck comes with. Apparently, the Wrangler is a series of tires from Goodyear with several different models and varying tread patterns.
I recently found an advertisement from Cars.com that showed a close up of a 2021 F-150 Lariat with the Sport Appearance Package and the 18" gloss black wheels. Thanks to the high definition details of the photos, you can see the truck is equipped with Goodyear Wrangler tires. If you look closer, you can see the Wrangler model specified as "Territory AT" and a size of 275/65/R18 (275mm width, 65 height/tall sidewall, 18 inch wheel for those wondering about the numbering specifics).
Ford F-150 Lightning XLT & Lariat Sport Tires: Closer Look at the Goodyear Wrangler Territory A/T 1609291117234
From what I can tell, this Wrangler Territory AT is a new tire from Goodyear and exclusive to the 2021 Ford F-150 (at least for now). I then found the listing for the Goodyear Wrangler Territory AT on TireRack.com listing. Here I was able to find a more direct look at the tire sidewall as well as the tire's tread pattern. Here is a closer look at both:
Tire Rack webpage:
Ford F-150 Lightning XLT & Lariat Sport Tires: Closer Look at the Goodyear Wrangler Territory A/T 1609291221000
Goodyear Wrangler Territory AT (OWL) sidewall view:
Ford F-150 Lightning XLT & Lariat Sport Tires: Closer Look at the Goodyear Wrangler Territory A/T 1609291260509
Goodyear Wrangler Territory AT (OWL) tread pattern view:
Ford F-150 Lightning XLT & Lariat Sport Tires: Closer Look at the Goodyear Wrangler Territory A/T 1609291322442
I've also posted the TireRack.com page so you can take a closer look for yourself -
https://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Wrangler Territory AT&partnum=765TR8WTATOWL
The Wrangler Territory AT appears to be a brand new tire from Goodyear as it is not listed on Goodyear's website yet, and does not have any user reviews of TireRack.com. Purely from a visual perspective, the tire seems to have a moderately aggressive tread pattern that should do a good job on road and light to moderate off-roading.
I also found a YouTube video on posted on our sister website, Bronco6G.com, from TFL's Talkin' Trucks podcast that goes into detail on this particular tire as it appears a black sidewall variant is one of the OEM tires for the new Ford Bronco. Isn't it a bit ironic that the Bronco has a tire that bears the name of its most formidable competitor? Anyway.....
Quick little history and info lesson, the Goodyear Wrangler tire is considered a sub-brand, or its own model. The Wrangler series has seven different models including the new Territory. The original Wrangler, the Goodyear Wrangler R/T was introduced in 1976, and continued to expand into multiple models in 1979, and is used for numerous light truck applications today.
Hopefully all of this history and research bodes well for a good first set of tires for those of us who ordered our F-150s with the XLT and Lariat Sport Appearance Packages!
KBKEITH
2021 F-150 XLT SCREW 5.5, FX4, 2.7EB
I like the appearance of the Territory AT as opposed to the Hankook AT2s that came on my XLT Sport with 20s. The AT2s are not very aggressive looking and appear to be different than the aftermarket AT2.
I hope the Goodyear offering works well for those that get it.
Knickell
Knickell
Kyle
That’s very possible that they are different. One of the things they mention in the video is how the original equipment tire can be specifically tuned to the vehicle while the general aftermarket tire of the same name may not be.
KBKEITH
That’s exactly what I was thinking after I did some research when I found visual differences between the two. Makes sense, but also makes me want something more aggressive. I’ll have to see how these OEM tires handle the snow as they are not severe snow rated like the aftermarket ones. That’s likely to happen any day now....
Knickell
Knickell
Kyle
Good luck! Let us know how it goes! The 60mm sidewall on your upgraded 20” wheels will hopefully keep the ride pretty pliable!
KBKEITH
Good luck! Let us know how it goes! To 60mm sidewall on your upgraded 20” wheels will hopefully keep the ride pretty pliable!
Thanks! We’ll see how it goes. I’ll report back when I get some data.
Yeah, the ride is actually pretty dang smooth. Can’t complain there.
Roger350
Roger
2011 Evo MR, 2015 Sonata Hybrid, 2007 Tahoe - Being Replaced by 2021 F-150
The 60/65 in tire size is an aspect ratio, not a direct measurement in mm. It means the tire height is 60% or 65% of the width measurement. 275mm x .60 = 165mm 275mm x .65 = 179mm. Twice these dimensions, plus the wheel diameter gives you the overall tire/wheel diameter.
Pipe
Jj
2018 Explorer
OEM tire versions specifically "tuned" to wear out in 20,000 miles is my experience.
Knickell
Knickell
Kyle
Thank you. Always learning, I’ve adjusted my OP.
Knickell
Knickell
Kyle
Lol, or a good reason to charge upwards of an extra $50 per tire because they’re “OEM” versus another brand...
ford2021
Adam
Iowa
2021 F150 Lariat Sport
sales
If anyone wants these 18's for the 2021 larait sport I have an aftermarket set of wheels and tires waiting at my dealer. They will have no miles on them and i plan to bring them home and sell them
ford2021
Adam
Iowa
sales
truck should be here early to mid february if there aren't any delays.
2017 Silver Lobo
Pittsburgh, PA
2017 F150 XLT and 1988 Mustang GT
Machinist
Tire Rack webpage:
"Isn't it a bit ironic that the Bronco has a tire that bears the name of its most formidable competitor?" said Knickell
I guess you didn't hear the whole thing Ford made Goodyear take Wrangler off the tires for the Bronco which are the optional Badlands 33" tires.
Knickell
Knickell
Kyle
Care to cite your source? I didn’t hear that anywhere in the video...
2017 Silver Lobo
Pittsburgh, PA
Machinist
I'm also a member on Bronco6G. There's a lot of talk on tires over there. I also remember reading an article in my Google news feeds about it.
