Best shocks for comfortable luxury feel?
robertcladner50
Robert
Chicago
2020 Ford F150
Designer
How can I make my 2020 Ford f150 smoother?
Ford F-150 Lightning Best shocks for comfortable luxury feel? 1-Rough-Country-2_-Leveling-Kit_
Ford F-150 Lightning Best shocks for comfortable luxury feel? 2-Bilstein-5100-Series-Shock-Kit_
Roger350
Roger
2011 Evo MR, 2015 Sonata Hybrid, 2007 Tahoe - Being Replaced by 2021 F-150
Are you running 20" or 22" wheels? If so, sell those wheels and tires and get some 17" or 18" wheels with taller sidewall tires. Most trucks with 20" wheels or larger pay a ride penalty for the bling.
If shocks are the way you want tp go, Bilstein are very good shocks. I would get ahold of their technical support/customer service, tell them the particulars of your truck, and what you want - better than factory ride, and let them suggest the best product they have to meet your needs.
robertcladner50
robertcladner50
Robert
Chicago
2020 Ford F150
Designer
Thank you for your help, Roger350.
Bryan Simon
Bryan
San Antonio, Texas
65 Ranchero, 66 ElCamino, 05 Ranger, and more
Maintenance
I kind of agree with this.
So many are not aware the tires are an important part of the suspension.
Taller sidewall tire will always be smoother to your hiney than a low profile tire.
I have 245/75 8 ply on my old Chevy. Max air at 80 psi.
Rides like an old Lincoln with 35
Only slightly stiffer with 55——-where I normally keep them
At about 70, the ride starts getting hard—never gone over 70
Those tall sidewalls absorb a LOT before it even gets to the rest of the truck parts.
Rgwinn
Rod
2021 F150 Hybrid
So, the problem is that the Truck (most Trucks) has a rear leaf spring/solid rear axle configuration, as compared to say a Navigator which has independent rear suspension with air ride.
The Truck will never ride like a Navigator. However; you get the ability to haul stuff.
I do think modern trucks ride way better now than they ever did in the past, it’s just not their strongest feature.
GABAR
P
GA
2016 F150
Most if not all trucks will ride smoother just by having some weight in the bed.
Believe it or not, they make sand bags just for your complaints / desire.
With that being said, sure, you can change the shocks but more than likely they’ll give you a stiffer and more firm ride compared to the stock shocks.
The Bilstein 5100’s that you posted via a picture is a very popular choice and they carry a lifetime warranty.
Is your 2020 F150 a 4X4?
Knickell
Kyle
Mazda Protege, Ford F-150
I’m going to second and third Roger and Bryan.
Simply put, going down to a smaller wheel size, means a larger (taller) tire is needed. Obviously, rubber is much more forgiving in absorbing road imperfections than the steel or aluminum of a wheel is.
Tireman
Adam
Nashville
2021 Ford F-150 Platinum, 2020 Cadillac Escalade
I’m a tire man
true, you will get a softer ride with the 18 inch, but the 20 inch wheel is going to handle better. It’s kind of a trade off.
Knickell
Kyle
Ahh, very good point I neglected to mention!
Roger350
Roger
Anyone driving a pick-up around corners hard enough to notice a handling difference between 18s and 20s should have bought a Mustang instead.
And what you lose in handling by going to a taller less stiff sidewall is offset by the reduction in unsprung weight that is easier for the shocks and springs to manage.
And that reduction in rotating weight will also allow the truck to accelerate and brake better, and increase your fuel mileage.
Of course all of those benefits will be about as negligible and hard to detect as that reduction in handling from the taller sidewall...
GABAR
P
GA
2016 F150
Take a look at the side wall on the 18 & 20 OEM tires on the F150.
There’s not much difference in the two and anyone saying that the ride is very noticeable between the two are fooling themselves.
Roger350
Roger
Which is also why I asked the OP if he had 22" wheels, and suggested 17" or 18" wheels as replacements.
johnday
john
barton city michigan
2020 f150 xlt/fx4/sport 2004 Ranger edge SC
Bilsteins as stated, are popular, work well, and reasonably priced, and most are happy with them. There's a "but" thrown in there though. If you like to keep all parts of your truck looking good, you'll be disappointed after one northern winter. The shock bodies are steel with a very poor coating on them, can you say corrosion? I had one set on my '17, and on my '20, I went back to aluminum bodied shocks.
hardlymoving
Larry
Montana
2021 Ford Supercrew 4 x 4 , 3.5 Ecoboost
For my 2017 F150 I threw two 70 lb sandbags in the box behind the wheel wells and it helped, I transferred the sandbags to my 2021. Both F150's came with the 18" wheels. Have noticed that when I added an extra spare tire the ride improved somewhat more. Driving with no weight in the box results in a jittery ride, in my experience adding a little weight smooths things out somewhat.
spud_41
Mountains & Desert
'21 Lariat 502a, Lead Foot 3.5L EB Fx4
Had them on my F-250 and after two winters you'd think the shocks were ten years old. I was not impressed, very stiff ride too.
