It's not feasible for everyone, BUT at $0.33/kWh, Solar is probably getting close to "no-brainer" status.Not a lightning issue, but my supply rate just went from .12 kWh, to .33kwh. Cost me 600 to drive the truck in nov. Mass.
Now looking at alternate suppliers. Lowest I’ve found is .17
Yup, our new garage service was activated 9/30, we had 16 days at the National Grid summer rates then it jumped to the winter rates on 10/15. We assumed incorrectly they would set up our third party energy provider as it is for the main house from Constellation, now we've requested the change. Once done we will be at 27 cents a kWh from around 38 cents (including delivery rates)Not a lightning issue, but my supply rate just went from .12 kWh, to .33kwh. Cost me 600 to drive the truck in nov. Mass.
Probably going to need a very large system. For reference, I have 8.8kW of panels with a 7.5kW inverter in sunny Tucson, AZ. I get 55-60kWh per day in mid summer and 40-45kWh in mid winter. Last year I produced around 18,000 kWh (which is about 90% of my yearly usage). Given how far north you are I imagine you will see a larger swing between summer and winter, but I think weather will make a bigger difference. I make less about half the summer average during monsoon season. We get clouds and storms during the peak production hours and that makes a big dent.Waiting for my first electric bill with lightning to see what size solar panel system I will need to get to near 0 usage. It looks like I’m close to 2,000 kWh for the billing period.
Got quotes for a 10, 13, 16 system. Maine does have net metering so can bank that summer production for the winter. My current commute of 550 miles a week also isn’t permanent. That will drop after I finish this school Program.Probably going to need a very large system. For reference, I have 8.8kW of panels with a 7.5kW inverter in sunny Tucson, AZ. I get 55-60kWh per day in mid summer and 40-45kWh in mid winter. Last year I produced around 18,000 kWh (which is about 90% of my yearly usage). Given how far north you are I imagine you will see a larger swing between summer and winter, but I think weather will make a bigger difference. I make less about half the summer average during monsoon season. We get clouds and storms during the peak production hours and that makes a big dent.
EDIT: Forgot to add that I don't have an EV yet, that's just normal home use.
That stinks. The main appeal for me on an EV is charging at home. Without it I would be hard pressed to buy an EV again.I haven't checked my bill but my assumption was that my all in cost would go from $0.25 to $0.41/kWh this month. I've been paying under $0.15/kWh at the local EA stations. I'm pretty much not charging at home at all. I do the majority of my charging at work for free and fill in the gaps, when needed, at EA stations. I only charge at home as a last resort.
