Fast "clicking" when exiting truck, Keyfob wont respond.
Madasahatter1138
Steve
Vancouver Island BC
Ford Transit
Electronics Tech
Minor issue but on several occasions, after parking the truck, turning it off, setting park brake and opening the door the truck begins a series of fast clicking sounds (like door locks)..The sound happens about 2 times per second. It will stop if I open the door. Also the keyfob does not function during this time.
It will last for about 3 secs, so its minor but kind of weird.
No Paak, keyfob only.
Anyine else here this series of clicks?
Also one thing I noticed during my weekend towing a trailer is that the turn signals wont stop blinking if I use the lane change feature of just pressing up or down without a full click..they just keep blinking and I have to carefully signal the other direction to stop them without signaling again the other way..it got sort of comical (and annoying..)
I know in past vehicles I had to upgrade my flasher module for the added load. I wonder if this is true here?
I have Tow Tech etc.
Thanks
Gimme_my_MME
Both sound like there is an electrical gremlin that should be addressed by your dealer
The Weatherman
Dean
South Central KY
On the flasher issue, have you used the Trailer Light Test feature to see if there is a problem with the trailer.
If you haven’t seen that function, it’s in the FordPass App.
Edit: It’s under Vehicle, Features and Settings, Trailer-light Check.
Madasahatter1138
Madasahatter1138
Steve
Vancouver Island BC
Ford Transit
Electronics Tech
Hi yes I have used the trailer light test and the trailer lights are all working properly.
