How to stop EA Charging at 30 free min cap?
jsaccio
Macan 4S
Active Member
Joe
Vancouver WA, USA
Miata, Macan EV 4S
Country flag
Is there a way to automatically stop charging before the 30 min free cap at Electrify America chargers?
krissrock
Macan 4S
Well-Known Member
Pennsylvania
Audi TT Roadster, Ducati Panigale, Cheverolet Trailblazer, Kia Sportage Hybrid
Country flag
i set a timer on my watch. you can stop the charging via the app...
Petzi
Macan Turbo
Well-Known Member
peter
Austria
Macan Turbo EV, 911 limited, Mustang V8 1967, GMC Gran Sierra 1971, Smart Brabus
Country flag
should it not be far above 80% after 30 min.?
krissrock
Macan 4S
Well-Known Member
Pennsylvania
Country flag
depending on the weather it may not. i had about two sessions over the winter where I didn't reach 80%... even when I started well above 10% ...like 20%
ColdCase
Macan 4S
Well-Known Member
Sam
New England, USA
Macan 4S, Mini SE EV, RAM 1500, Ducati 916 Varese, C4 Corvette Z51
Country flag
In cool weather and battery not preconditions I don't see more than 75 kW from EA 350 KW chargers. Very easy to run out of free time. On better 175kW days I usually don't run out of free time.
Rocket Roger
Macan 4
Roger
San Francisco Bay Area
98 Audi A4 2.8 Quatro 5Sp, 2018 Audi A5 Spt Bk, Niss LEAF, Yam XSR, Macan 4
Country flag
You could adjust the final charge % until you hit what the car estimates is 30 minutes from when you start
seabird
Macan 4S
Earth
Macan 4S, Audi RS5
Country flag
That's a de-rated charger, not weather or conditioning. Preconditioning can't make a 100-200kW difference.
With zero preconditioning in freezing temperatures, I still get ~200kW within a minute of plugging into a 350kW station, peaking around 230.
ColdCase
Macan 4S
Well-Known Member
Sam
New England, USA
Country flag
Thanks. I was mislead by all the EA chargers limited to 75kW in my nearby station, even when not busy. When I'm out on the road with warm batteries charge rates are much higher. I didn't give it a thought that it may be the station.
jsaccio
Macan 4S
Active Member
Joe
Vancouver WA, USA
Miata, Macan EV 4S
Country flag
How do you get the app to recognize the car? The Plug&Charge feature works for me but when I open the EA app it does not know I'm charging.
krissrock
Macan 4S
Well-Known Member
Pennsylvania
Country flag
that i don't know about..haven't heard of that issue before. I get notification when charging starts and ends, or any errors....
daveo4EV
Macan Turbo
Well-Known Member
Santa Cruz
Macan Turbo,Cayenne Hybrid, 911(s) GT3/Convertable
Country flag
I understand the goal of this request - but unfortunately do not personally know of any way to achieve it…
however one should consider the following:
EA charges by the "kwh" - not time - so after the 1/2 mark the charge rate is quite a bit slower than it would've been at the beginning of the process - so while you may not be able to stop at the exact 30 minute mark - you can take solace in the fact that the rate of accumulation for costs will be quite a bit slower given both the slow charge rate and therefore the relatively small amount of kWh's provided past the 30 minute point in most EA sessions…
