- First Name
- Lasfit
- Oct 7, 2023
- Rancho Cucamonga. California
- Ford F-150 2021
It is our goal as a company to constantly redefine the quality and service standards of the lighting industry and continually offer our customers the most premium lights you can buy with the same budget. We pursued the same aim with off-road lights. In this thread, we will give a detailed introduction to our LED light bars for you to learn about them better. Feel free to ask us any questions and make comments!
Lasfit LED Light Bars - High-Quality Combo Lense Light Bar For Your Budget
Featuring flood and spot combo pattern, Lasfit LED light bar gives outstanding light performance with its high brightness and authentic output lumens. It has a rugged lightweight aluminum housing with high impact PC lens, perfectly designed for overlanding, off-roading, and any outdoor recreation.
With 12" 22" 32" 42" 52" of sizes available, you can choose the right size based on its wattage (intensity) and compatible mounting options. Usually 12" - 32" bars are mounted in the grille or on the front bumper, and 42" - 52" bars are on the windshield or roof.
Product Features
1. High Brightness - Osram Chipset & Smooth Reflector
We use Osram's OSCONIQ® P 3737 chipset for our light bars. This high power LED chip delivers high performance to last long. When using the light bar for a road test, the smooth reflectors will largely help focus the light down the road.
2. Flood and Spot Combo Beam - Shines Far and Wide
With combo lense functioning, it does a really nice job of focusing the light down the road far and wide. Just like your headlights, there's a focus beam performing and you'll be surprised by how well our reflectors are formed as a combo lense.
3. IP67 Waterproof - Under Water for 30 Mins with No Moisture In
Made of high-quality aluminum and with high temperature seals on, our light bars are holding up to standard under water (6 feet) for 30 minutes with no moisture getting into the housing. (After rigorous testing in Southern California with a temperature sometimes over 110 degrees fahrenheit)
Waterproof Video:
Visual Effect
Check out more installation info:
Toyota 4Runner 32" LED Light Bar Behind the Grille Kit - Different Height Positions Review
Learn more about Lasfit light bar: LASFIT Off-Road LED Light Bars 12 22 32 42 52 Inch Spot Flood Combo Si
LASFIT
For Better Vehicle Life!
Product Features
Waterproof Video:
Visual Effect
LASFIT
