Latest Update Broke My Center Screen?
Notallthosewhowanderarelo
Thomas
Rochester, NY
2021 Ford F150 Powerboost
Hi all,
I just got an update on the truck and app, and within two minutes of driving my nav failed, Android auto disconnected, and now the screen is frozen and won't respond to touch.
Any way to reset the center screen? Tried turning the truck off and back on.
Thanks!
Ford F-150 Lightning Latest Update Broke My Center Screen? PXL_20211222_164703127
Caneman88
Ron
San Antonio TX
2021 Powerboost F150 Platinum ,2009 370Z
Pella Windows and Doors
Thought I read somewhere hold the forward button on steering wheel and the center console at the same time and it resets the screen worth a try
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Hi all,
Thanks!
Sounds like your APIM might be shot. Probably not much you can do about it except what the screen says. You could try cutting and restoring power to the module and see if it reboots. Disconnecting the negative to the starting battery won’t do it—the aux battery will still provide power. But you could try pulling the fuse. It’s (I think) fuse 15 located in the BCM fuse box. The BCM fuse box is in the passenger side footwell. Owner’s Manual pp. 451-52.
3DogKnight
2020 Escape Titanium - 2021 F150 XLT
100% retired
Hi all,
Thanks!
This is probably a shot in the dark but there were a lot of posts on this site relating to fuses that were not pushed in/seated all the way. Maybe, just maybe, this could cure the problem.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Hi all,
Thanks!
Your not alone. Was yours stuck downloading the updates over the last few weeks?
Thomas
Rochester, NY
Hi all, it eventually figured itself out. So it may just be busy doing other things due to the update and then freeze up. I turned the truck off for about 10 minutes and then came back and it was good.
