OBD scanner
Rob G
Rob
Monmouth County NJ
GV60 Sport, Bronco BL Sasquatch, Taycan 4S
I bought an OBDLink CX which I plugged into the OBD2 port on my MME, connect it to via Bluetooth LE to the app that came with it. I cannot seem to connect an app to view the data though. It doesn’t see the device via BT LE or regular BT.
I was trying to connect Car Scanner. I know iOS 15 introduced some trouble with connectivity so before I make myself nuts has anyone done it with iOS 15 or later?
Firestop
Firestop
I searched their Support Forum, saw what appeared to be references to some BT connection issues, but no submissions similar to your. You may want to submit a Support Ticket…..
https://www.obdlink.com/submit-a-support-ticket/
Rob G
Rob
Monmouth County NJ
I figured it out with some help. It timed out because I didn’t connect right away, it’s a security feature. i reset everything and did it again and it worked just fine.
