Remote Start from Key Fob - It Works!
Kansan
Wayne
2024 Flash
Civil Engineer
Update: I see now this has already been discussed. Sorry for the repeat.
Member sstevetx mentioned this in a post about programming a key. I tried it and it works. It’s a cool capability so I’m pointing it out for everybody that’s interested.
If you program a key fob to your truck that has traditional remote start instead of the frunk button, you can remote start the truck just like an ICE F150. So, if you can’t start the cabin warmup with the app, you can start it from the key fob. It functions just as if you had started it from the app.
With the cold weather we’ve been having I’ve found that at very cold temps the BMS will shutdown several features to preserve the 12v SOC. This happens even when the 12v is at a high SOC - happened to my truck after 9 hours at work with the 12v at over 90% charge with outdoor air temps below -5F. One of the features that gets shutdown is the connected features modem. So, when I most wanted to preheat the cabin my app couldn’t connect.
If you decide to try it, make sure to pick a fob with the right frequency. My 24 Flash key fob is 433 MHz. Earlier trucks were 315 MHz. Best approach is to check your Fob FCC ID to confirm your frequency.
