Rough Country Bed Mat
mnstang
Nick
MN
2021 F-150 Lariat PB Leadfoot
US Gov
So, I've been looking around at getting a bed mat. My 13 platinum had a spray in liner but got so many stains on it that when I sold it, it was looking rough. Was thinking of adding a bed mat OVER the spray in liner. Do people do this? Is the rough country bed mat good? Was also looking at the husky liner one too, any suggestions?
xXChartmanXx
San Diego, CA
2011 Explorer, 2021 VW ID.4, 2021 F150 Lariat
CyberSecurity Engineer
Following this because I was thinking of doing the same thing.
zdjelar
Saša
Houston
2021 F150 Limited (AMB)
Energy
I'm definitely doing this. I'm going to do the Line-X liner but have also purchased a Black Armour mat for a number of reasons... 1) a bit more weight on the rear wheels (controversial, but like a bit more traction and that mat is like 100 lbs.), 2) gripper surface for less sliding and 3) something to dampen anything that falls and just generally to help keep the bed protected for longer.
That particular mat is apparently one of the best ones due to thickness, material (made from recycled tires) so the rubber is vulcanized, etc.
Jim Bandy
James
2021 F150 Limited 4x4 Powerboost (Hybrid)
I'm absolutly going with the Black Armor Mat. Your spot (I'm the same also) on with the reasons.
mnstang
mnstang
Nick
MN
US Gov
Thanks guys, I guess I'm not the only one with the same idea! The black armour one is $250 it seems, is it just the thickness thats the main difference from the $100 Rough Country one? RC says its 3/8" thick, seems like a huge price difference just for 1/8" more.
Eco_Beast
Kevin
Maple Ridge, BC Canada
2022 F150 3.5L EcoBoost
Electrician / Graphic Designer
I love my Black Armour, I've seen the rough country one and its only 3/8 at the thickest parts, half of the mat is probably 1/8th. the BA one is 1/2" thick all over. I think mine weighs 100 lbs. They have 10% off right now too. https://www.blackarmourbedmats.com/ford/
MN_Hockey_Fan
MN
09/14/21 F150, 10 Expedition
I'm going with a bedrug mat. I have one in my current truck with a plastic liner and will get a new one with the spray in liner. It really stops items from sliding around the bed and has cushion when you need to crawl around the bed. They are also breathable. Doesn't solve the added weight benefit. Mine still looks almost new after 6 years, very easy to clean it with soap and water.
https://bedrug.com/bedrug-classic-bed-mat/2021/ford/f-150 $163 for a mat for a spray in liner.
Dan M.
Dan
Fayetteville NC
2018 Ford F-150 Lariat
Retired Army
I also have a bedrug that I've had for 8 years and I've used it hundreds of time when I haul stuff in the bed. It's very durable, light weight and stops items from sliding around. When I get my 2021, it'll go in it. Still looks new, just wash or sweep it off when it gets dirty.
mnstang
mnstang
Nick
MN
US Gov
I’m assuming you would take this out hauling bulk mulch and rocks? I’m looking for something just to keep in.
Andyc
Sussex UK
2014 Shelby Raptor. 2005 AEV Jeep TJ stroker supercharged. 2007 Navara
Business owner
What are peoples experience with the genuine Ford rubber bed tray.
Ford F-150 Lightning Rough Country Bed Mat 1613166050160
he
MN_Hockey_Fan
MN
Yes. I have removed it when hauling mulch and dirt. You wouldn’t have to though. Either way you are going to spend time hosing out the bed after with this. Assume you still would have to remove the rubber mat as well for mulch and dirt afterwards to clean up.
Captain Chaos
2022 F150 screw
Heavy equipment operator
I bought the rough country bed mat while I wait to get it lined. I'll probably still use it after it's lined as well. I was surprised how good it is for the price. It's thick, and it's rubber, not some harder, plastic type stuff. I would definitely recommend it.
