- First Name
- Lasfit
- Oct 7, 2023
- Rancho Cucamonga. California
- Ford F-150 2021
- "Really good to keep floor carpet clean in my truck As good or better than more expensive other mats. Great value for the money"
- "This was a perfect fit for the f150 lightning pro, front and back rows. If you need a set of protectors for the lightning 2023 model, look no further, durable, tough, and laser accurate fit."
After you find these 2 reviews, can you find which is for Custom Fit Floor Mats or Universal Fit Floor Mats?
Certainly, it is easy to pick the correct answer. When it comes to floor mats for our beloved vehicles, a common topic of discussion among car enthusiasts and everyday drivers alike is the choice between custom fit and universal fit options. You know, universal fit floor mats often come with the appeal of being budget-friendly. They are relatively inexpensive, which means if they get too dirty or worn out, replacing them doesn't cause a big dent in your wallet.
However, let's talk about custom fit floor mats. While they may have a higher upfront cost, they are truly a worthy investment. These mats are crafted with precision to perfectly match the contours and dimensions of your specific vehicle model. Not only do they look sleek and stylish, enhancing the interior aesthetic of your car, but they are also incredibly durable. They can withstand heavy usage and still maintain their quality and appearance. You see, custom fit floor mats aren't just about protection; they can also add a touch of luxury and sophistication to your driving experience. And the best part? Their durability means they'll serve you well for a long time, making the initial expense seem well worth it in the end.
Durability and Material Quality
Custom fit floor mats are typically made from higher-quality materials that are specifically designed to withstand the wear and tear of your vehicle's interior. Such as the TPE material, Lasfit Liners use 100% TPE to make their products. It is easy for us to know that it is eco-friendly and all-weather protection. They are often more durable and can last longer. For example, if you frequently carry heavy items or have kids who spill drinks and food, custom mats made of heavy-duty rubber or thick carpet material may be a better choice. Universal fit mats, on the other hand, may be made from less durable materials and may not hold up as well over time. If you need a short-term solution, cheap universal car mats are a quick fix, but custom car mats will definitely get you the most bang for your buck long term.
Ease of Installation and Removal
Universal fit floor mats are generally easier to install and remove as they are designed to fit a wide range of vehicles. They simply need to be placed on the floor. Custom fit mats, however, are designed precisely for your vehicle model and may require a bit more effort to install correctly, but they fit snugly and don't move around. Such as the anti-slip button, it needs to take the right side or will not make it install at the right way. But Lasfit has the update design and use different texture to driver seat and second row logo, making it easier to correct the side of floor mats. Therefore, you don't need to worry about the install issues.
Non-Slip Surface
Custom fit mats usually offer a better non-slip surface as they are tailored to the contours of your vehicle's floor. This is crucial for safety, especially when you need to brake suddenly or drive on slippery roads. Universal mats may not provide the same level of grip and could potentially shift under your feet.
Maintenance and Cleaning
Both types of mats can be cleaned, but custom fit mats are often easier to clean as they fit the floor precisely, allowing for better access to all areas and the dirt on the mats are convenient to clean by the normal high pressure water gun. With universal mats, dirt and debris may accumulate in the spaces where they don't fit perfectly, and you have to use some chemical cleaning agents,which will takes some time to finish. Otherwise, it is not easy to make it dry and take it back to your car.
Thickness and Cushioning
Custom fit mats can offer better thickness and cushioning, providing more comfort for your feet and reducing fatigue during long drives. Universal mats may be thinner and less cushioned.
Brand Reputation and Reviews
Lasfit initially focused on vehicle headlights. However, in 2019, it ventured into the production of car floor mats and trunk mats. Since then, by constantly receiving feedback from customers and various channels, the brand has been continuously optimizing and improving its products. As a result, it has gained a group of loyal fans. Here are some of their sharing.
The development of Lasfit's car floor mats is an ongoing journey. During the last 5 years, we are committed to providing better and better products and services. If you are interested, we sincerely hope you can start experiencing our products. Our excellent customer service will make you feel at home. For instance, we have continuously improved the material of the floor mats to make them more durable and resistant to wear and tear. We have also designed them to fit perfectly in different car models, ensuring a seamless and aesthetically pleasing look. The journey of improving our car floor mats is never-ending. We will keep listening to customers' needs and keep innovating to bring you the best products and experiences.
In conclusion, the choice between custom fit and universal fit floor mats depends on your specific needs and usage. If you value a perfect fit, durability, and a non-slip surface, custom fit mats might be the way to go. But if you're looking for something quick and easy to install and remove, and don't mind sacrificing some fit and quality, universal fit mats could work for you. Consider your daily driving habits and priorities to make the best decision for your vehicle.
