Wiper blade hitting A-Pillar?
thealbs
Macan 4S
Well-Known Member
Manchester, UK
Macan 4S Slate Grey Neo
Country flag
Has anyone else experienced the wiper blade hitting the a-pillar when operating, and causing a tap-tap-tap noise every time the blades clear the windscreen?
Mine has been doing it for a while, but we had a downpour today and the wipers went into overdrive and it sounded like someone was playing a bass drum solo.
taycanstuff
Macan 4S
Well-Known Member
UK
Ice Grey 4S
Country flag
Drove in the down power today and not noticed.
Adding to this, the macan drove really well in the rain, unfortunately saw a M4 in my rear view mirror fish tail it, spun across the motorway from the outer lane into the hard shoulder, thankfully they didn't hit anyone but think the grass/barrier stopped him so car damage only.
Glad I went 4S.
Flighty
Macan 4S
Active Member
UK
Macan 4S, Previously Macan GTS, Audi RS4
Country flag
Yes got this exact problem, it’s very annoying. I was due to have it looked at by OPC but fell ill so couldn’t make the appointment.
RickDCMD
Macan 4S
washington DC
Macan 4S
Country flag
Yes, I got Macan 4 loaner, with the blades hitting the B pilar, I went back next day to the dealer and they repositioned the blades “manually removed and re-positioned “ and problem solved. In the beginning they thought it was a software issue, but no is just a mechanical work of 5 minutes.
thealbs
thealbs
Macan 4S
Well-Known Member
Manchester, UK
Country flag
Thanks. Mine is due to dealer soon so will add this to my snag list too.
alxman
Macan 4S
Well-Known Member
Atlanta
Macan EV, BMW X6, Tesla MX
Country flag
You can probably DIY. Just loosen the bolt that holds it in place, remove and reposition the wiper.
thealbs
thealbs
Macan 4S
Well-Known Member
Manchester, UK
Country flag
What else is on your snag list?
Mainly the ongoing passenger window issues but also...
- this one
- ill fitting charging cover on drivers's side
- faulty steering wheel column adjuster
... and there's a couple of weeks before it's booked-in, so will be on the lookout for others niggles.
