Nightshade
- First Name
- Aidan
- Sep 4, 2021
- Alberta, Canada
- '22 Ford F-150 Lariat | '22 Ford F-350 S/D Tremor
- Occupation
- Sup/t. Wildland Firefighter with Alberta Wildfire
Anyone looking for DRL LED Bar to go from dimmed to boosted bright, this is the only forscan mod you have to do. Works perfectly in all modes, including Bambi mode and marker mode. Stays bright all the time! Huge thanks to @Hectort713. Confirmed working in 2021 F-150 XLT, Lariat and Tremor. Other trims, comment below if working. As always, make a backup before doing this.
BCM: 726-42-01 -> x2x2 - xxxx - xxxx
*do at own risk.
EDIT; also works on ‘21 F-150 Platinums.
*do at own risk.
