Brock_smith41
I love the Icon’s. I just don’t really off-road at all so coilovers seem excessive. That’s why the eibach’s looked like a good option for me for $1k less. But I was unaware of the part numbers being the same for most of them until now. This is my first brand new truck, so I want to do everything the right way. I guess I’ll either be waiting for a redesigned kit or bite the bullet and get Icon’s.I too have been searching hi and low for a coilover leveling kit that has been engineered specifically for the 14th Gen F-150 and accounts for the slight changes in geometry. The Eibach kit looks legit, but beware that if you google the P/N, several vendors list it as fitting 15-20 or 15-22 models. So I'm not convinced that the struts been redesigned.
Eibach E80-35-035-01-22 F-150 Lift System Pro Truck Stage 1 4WD 2015-2022 (cjponyparts.com)
I've found this discrepancy common across many of the popular/big name brands. Roush Performance has addressed it, but only by lowering the spring perch by 5/8" of inch on the 15-20 kit. So far, the only company that has convinced me that they have in-fact researched, designed, and tested is ICON. Their kits aren't exactly cheap, but suspension components may not be the best thing to skimp out. I also suppose there is the "get what you pay for" catch... I'm undecided at a price tag of around $1,700.
2021-UP FORD F150 4WD 0-2.75" STAGE 1 SUSPENSION SYSTEM 2021-UP FORD F150 4WD 0-2.75" STAGE 1 SUSPENSION SYSTEM - Icon Vehicle Dynamics
2021-UP FORD F150 2WD 0-3" STAGE 1 SUSPENSION SYSTEM 2021-UP FORD F150 2WD 0-3" STAGE 1 SUSPENSION SYSTEM - Icon Vehicle Dynamics
Please post on the thread if you happen to come across something else. I may wait it out till spring to see if other manufactures catch up in the aftermarket parts. Seems like it's taking them forever...
Cheers!
What engine do you have? I’m curious about whether it fits on a 5.0 considering the description showing it for 3.5’s onlyI had the Eibachs put on about a month ago. Truck is perfectly level and rides great. For the price, and what's actually available, I'm happy. Handling is vastly improved over stock.
I think you’ll be just fine. If you Google the part number it’s the same for the 2015+ F150. Depending on the vendor it list all kinds of trims and engines. It also available for as low as $550 from a few places.What engine do you have? I’m curious about whether it fits on a 5.0 considering the description showing it for 3.5’s only
IWhat engine do you have? I’m curious about whether it fits on a 5.0 considering the description showing it for 3.5’s only
I have the 5.0 with max tow. Had my dealer install the eibach struts only. They used the top spring perch, I thought I was going to get 2” of lift but got 2 3/4”. I went with it. It has been several months now and about 3k miles. Ride and handling great. It settled in at about 2 1/2” no problems so far.What engine do you have? I’m curious about whether it fits on a 5.0 considering the description showing it for 3.5’s only
3.5 EB in mine.What engine do you have? I’m curious about whether it fits on a 5.0 considering the description showing it for 3.5’s only
That’s the first I’ve heard of the engine options having different struts. So if you install factory 3.5EB struts on a 5.0 you should get 3/4” of lift?After the install, I called Eibach. I ask why I got 2 3/4 " of lift. He though it was because the 5.0 and the 3.5 have different struts, and different height spring perch. Also maybe because I have max tow. But if you want only 2" of lift you can chose a lower spring perch. Kind of a trial and error. I stayed with what I had because I didn't want to pay more to use a lower perch. If you go with stage 2, I believe they use a spanner wrench to adjust the height. But they are more of a off road strut, way stiffer than I needed.
I’m looking for 2 3/4” personally. I’m wanting 295/60R20’s with 0 offset wheels. Which is just enough to not work on a 2” level without having some decent cutting done. Hoping the eibach’s are a perfect fit for what I’m going forAfter the install, I called Eibach. I ask why I got 2 3/4 " of lift. He though it was because the 5.0 and the 3.5 have different struts, and different height spring perch. Also maybe because I have max tow. But if you want only 2" of lift you can chose a lower spring perch. Kind of a trial and error. I stayed with what I had because I didn't want to pay more to use a lower perch. If you go with stage 2, I believe they use a spanner wrench to adjust the height. But they are more of a off road strut, way stiffer than I needed.
