2022 MISSING FEATURES: Ambient Lighting & Differences In DEATC between 2021 and 2022 F-150s?
DT400
Darrell
Colorado
79 Scout II, 90 Mustang gt, 95 F-150, 22 F-150
Just saw a review of the 2022 Bronco Raptor on TFL Talk. The new Bronco Raptor still has the temperature display on the HVAC control knobs. Not sure if this is a pre-production model or not. I haven't been able to find any reviews of the 2022 regular full-size Bronco for comparison. So it might be only available on the Raptor version.
if so a chip shortage may not be the reason the F-150 has lost this feature for 2022. It's also possible that since they'll make comparatively few Bronco Raptors compared to F-150s, but they can only get some chips and they decided to use them on the Bronco Raptor . Would really like to know the actual reason Ford removed this feature.
Darrell
JHForman812
Indiana
2022 F350
if so a chip shortage may not be the reason the F-150 has lost this feature for 2022. It's also possible that since they'll make comparatively few Bronco Raptors compared to F-150s but they can only get some chips and they decided to use them on the Bronco Raptor . Would really like to know the actual reason Ford removed this feature.
Darrell
the normal 22 broncos definitely lost these, look over on bronco6g they got a thread going too lol
iceman77
Pete
2022 Ford F-150 Platinum
Is there a way to remove the HVAC temp readouts from the SYNC screen after replacing the HVAC knob assembly with digital readout ?
JHForman812
Indiana
2022 F350
Look at 7D0-02-02-*xxx-xxxx-xxxx
the spreadsheet has Status bar temperature enable/disable on that line. see what you have there currently.
ARegularJoe
Joe
Feb 2 Order: 22 Lariat 500A/3.5 EB/FX4/Max Tow/+
I was perusing the interwebs in an effort to bring you guys the most breaking and cutting-edge Gen14F150 information and my eye caught this possible difference while looking at a 2022 F-150 Tremor that was for sale.
Ford's "DEATC" (Dual Electronic Temperature Control) appears to have been modified for 2022 F-150s.
For the 2021 model year, trucks with the dual zone climate control had two knobs with a small screen that gave you the exact temperature degree reading of each zone. For 2022 it looks like this was done away with for some reason.
Bear in mind, the 2022 truck may not have been turned on, but the big power button in the middle seems to suggest the layout for the 2022 model will be slightly different. Maybe the red/blue adjusts around the knob as the user sets the temperature? Is it some other cool new feature, or simply a cost cutting measure because the little screens were too expensive?
(My) 2021 Ford F-150 with the DEATC:
A 2022 Ford F-150 Tremor with the DEATC:
2021 F-150 on top, 2022 F-150 on the bottom
If any of you guys who have your 2022 F-150s with the DEATC can chime in and adivse, let us know!
NEW VIDEO UPDATE:
Confirmation of the cup holder ambient lighting delete for 2022 at 3:15:
2022 Ford F-150 Lariat at Night! | Better or Worse? - YouTube
It appears that several electrical appointments were chaged from 21 to 22. I wonder when we will see information on jailbreaking those features back into the F150. I suspect that some of these extras deletes are available at the point of delivery save for the actual lighting output device. E>G. the wiring connecter is there, just not the light.
iceman77
Pete
4 =MAC Disabled • SBT Off • DFC Disabled • CAS Disabled
ARegularJoe
Joe
So I tried to get wiring diagrams for either the 21 or 22 from Helm with no success. Seem ford is holding out till the end of 22 to provide? Was going to see if the 22 deletes were just a matter of not providing the device psst its electrical socket. If so, just buying the parts would likely be the toughest part of having many of those deletes restored. The temp knobs may be a little tougher. May require panel removal and replacing the whole control.
JHForman812
Indiana
2022 F350
if you’re talking about the missing lights here’s what’s been found….
cup holder plug is gone, there’s a guy that makes a harness to put it back
media bin light, there’s a 22 platinum that the connector was present, and a 22 king ranch that it wasn’t present on there’s a guy that makes a harness for that also
glove box light not a single truck has had this connection it can be added to the same harness that a guy makes for the media bin light
climate control missing digital readout, can be restored if you get a climate control head from a 21 that has all your features it’s been done and confirmed working on multiple trucks.
ARegularJoe
Joe
That’s all great info. Thanks John!
thomhunt
'22 F-150, '96 F-150, '13 Fusion
Yup! That did the trick!
Looks muuuch better! Thanks for the info!
Did this work immediately for you or was there any delay before the temps disappeared?
I also had a 4 for MAC Disabled • SBT Off • DFC Disabled • CAS Disabled which I replaced with a 0, but so far temps are still showing.
I didn't disconnect the battery but might try that if no change after a couple drive/ignition cycles.
JHForman812
Indiana
2022 F350
Go under the wrench icon in forscan and perform an APIM reset it will take care of it instantly.
