Disappointed in B&O Unleashed
Jefmedia
Georgia
2016 F-150 Limited
It is my understanding the only way to get Dolby Atmos from a streaming service, is if you have either Tidal Uncompressed or Amazon HD, both of which are paid subscriptions. There may be additional services, but I believe to carry the additional sound information required for Atmos it has to be uncompressed.
SonnyDigs
Sonny
2021 F150 King Ranch
Yep
Not sure that makes a difference..
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
Well, a Bluetooth connection from a phone is either A2DP (one way stereo) or SCO/eSCO (bi directional phone call) so you can't send true Dolby Atmos anyway. I just wondered if the simulated effect would get any sound to the headrest speakers so I can listen for it some day.
Smitdog
2021 F150 Limited PowerBoost Smoked Quartz
Gainfully Retired
Instead of using Bluetooth to connect, would it help sound quality if using a hardwire connection (from phone)?
BMWtoF150
Marty
SC
2021 F150 King Ranch, 3.5 Eco
Retired, Part Time Consultant
I use a usb drive. The sound quality is good. The sound separation is great. You can hear all the speakers. You can still select artist, albums, genre, etc when using a usb drive.
Jerry Can
Calgary
2021 F150 KR Powerboost, 2-tone Rapid Red, 157”
Fuel Container
It’s my understanding that wireless Android Auto and Apple CarPlay both use wifi rather than Bluetooth. If that’s true, the bandwidth limit is negligible, and therefore the audio quality should be the same as a wired connection. However, I don’t have my truck yet, so I can’t test this assumption
zdjelar
Saša
Houston
2021 F150 Limited (AMB)
Energy
CarPlay is a Wifi connection, not BT. It’s also why you can’t be in wireless CarPlay AND car hotspot (which is why that feature may be useless to most drivers and perhaps only valuable to their passengers).
SonnyDigs
Sonny
Android Auto is BT...
Don't know about Apple car but would have to assume it's also BT..
Most people don't have WIFI in their vehicles and in my case I've always connected with BT, I've never had WIFI in a vehicle..
Orlando150
Orlando, FL
Ford
Some info here: https://g05.bimmerpost.com/forums/showthread.php?t=1748129
In short wireless CarPlay should support CD quality audio (more than enough for Apple Music, Spotify, etc) and it uses a lossless format to transmit the audio to the system via wifi (the same they use for AirPods). If you have higher quality audio file on your phone (ex: you have a 24bit/96khz FLAC rip) you won't get that quality preserved across the connection (it's only lossless up to CD quality). However if you do have a file like that you probably aren't outputting that quality through your phone anywhere without a special adapter because the lighting port on the phone also maxes out at CD quality.
A USB drive with a higher than CD quality file would be the only way to get the maximum possible sound (on a BMW system at least). However 99.9% of people would be unable to tell the difference.
BMWtoF150
Marty
SC
Apple CarPlay uses the in car network over WIFI. When you start the truck, the iPhone initially connects as bluetooth and then disconnects and then hooks up as CarPlay If you change your connection to bluetooth while CarPlay is active it will disconnect CarPlay and connect the Iphone as a bluetooth device. If you change your wifi to anything other than the in truck network CarPlay will not connect.
As far as I can tell Sync 4 has some gremlins to work out. I cannot playback music correctly from my iPhone 12 and Android users seem to be having numerous issues. There have been a few times that CarPlay would not connect and nothing in the setup had changed.
SonnyDigs
Sonny
Big problems getting Android to work properly, WIFI or BT..
Sometimes it will work but not totally..
The volume goes way down when connected to the phone compared to the radio..
Radio sounding much better..
Orlando150
Orlando, FL
Ford
AA seems to be pretty buggy for any car. Lots of issues reported: https://www.reddit.com/r/AndroidAuto/ Maybe you can find a solution for yours?
Not that CarPlay is perfect (I still have occasional connection issues on Sync3) but it probably helps to only have one hardware manufacturer who also writes the software.
SonnyDigs
Sonny
Thanks
currybob
Bob
Alexandria Alabama
2021KRF150 PB; 2020 LexusRX350; 2021 Mazda Miata
Retired Physicist from federal government; Army Veteran
I have Atmos turned on and B&O set to surround sound..
It all sounds good to me..
Couldn't pay me to listen to Sirius..
Yeah, to me the music sounds better (fuller) on FM over satellite as long as it is a strong signal. Not problem in my area. About the only thing I listen to on Sirius is the comedy channels, I don't renew when the free is over. My wife has it and I have it on my phone from that account.
