Tire size options for OEM wheels with 2" level?
F150Trucker
Nashville
2021 F150 Platinum
I've got a '21 Platinum coming in a few weeks and trying to decide on a tire size. Planning on doing a 2" level and want to stay with OEM Wheels. Previously I've run 285/60 r20 BFG KO2's, but was considering other options of 275/65 r20 or 285/65 r20. Has anyone got pictures of any of these set ups on their 2021?
05RubiconLJ
Matt
Arkansas
'05 Rubicon LJ, '21 F-150 Platinum Powerboost
My Platinum will be built this coming week and I am planning on the same setup. Photos of leveled trucks are not all that consolidated, but I would suggest starting in the Show and Tell Threads. Some guys post new threads with their builds and others post in the ā€˜color specificā€™ threads.
As for size, 295/60-20 seems to be the most popular. 275/65-20 is starting to pick up steam. The 275 is a more common size across manufacturers, so prices are not as steep. A lot of members have gone to aftermarket wheels, too. I am not.
bz-agg is running 285/65-20ā€™s, but has not had his level kit installed. They look nice.
https://www.f150gen14.com/forum/threads/smoked-quartz-f-150-2021-club.391/post-10574
F150Trucker
Nashville
2021 F150 Platinum
Appreciate the feedback. 295/60ā€™s are a little wide for what Iā€™m looking for and Iā€™m concerned that the 275/65 may look a little narrow. Iā€™m leaning 285/65. Will keep checking posts of other trucks.
F150Trucker
Nashville
2021 F150 Platinum
What was your order date by the way? I ordered 1/13 and got a vin about 2/10, but donā€™t have a build date yet.
05RubiconLJ
Matt
Arkansas
I ordered mine 1/25, received my Vin on 2/8 with a build date of 2/26. My window sticker popped up this past Wednesday with a blend date of 2/22, so looks like the truck is on schedule. The Ford tracker has never shown the build date, but my dealer had the info. Keep checking https://shop.ford.com/vehicleordertracking#/ for your window sticker, it will indicate the start date of your build (if the dealer doesnā€™t tell you). Window stickers have been popping up about 5 days before the blend date.
While Iā€™m not shopping tires on a budget, I am likely to go with the best size for the money. If 275/65 is $40 cheaper than 285/65, the size difference is nominal enough to just save $160 and run a 275. I know a 275/65 is noticeably less expensive and made by more manuf. than a 295/60.
F150Trucker
Nashville
2021 F150 Platinum
Good info. Mine is probably really close to yours. I donā€™t really like the look of the 295/60 tires, so not an option for me. Iā€™ve run a 285/60 (33.5x11.2) for the last few trucks Iā€™ve had. I like them but want something a little taller. The 275 sounds perfect, but I donā€™t want them to look to skinny. Theyā€™re probably fine and the right tire - Iā€™m leaning that way. Appreciate your feedback.
Asphaltman
Salt Lake City
2021 F150 (produced 2/11) 2018 F-150 1997 F-250HD
Entrepreneur
Whatā€™s the Max size tire with a 2ā€ level and 20x9 wheels? Iā€™ve previously ran 285 65/20 and liked that size, but unknown if it will fit without rubbing.
F150Trucker
Nashville
2021 F150 Platinum
Probably a 285/65 or 295/60 is the max with a 2ā€ level and no rubbing. 35ā€™s probably wonā€™t fit. Iā€™ve seen pictures of a 285/65 with no level which surprised me. It seems like the 21ā€™s have more room. But Iā€™m still waiting on mine.
05RubiconLJ
Matt
Arkansas
F150Trucker
Nashville
2021 F150 Platinum
I had not. That one looks really good. I wish there were more pictures of that.
rathbunr5
Bobby
Connecticut
2022 Ford F-150 Lariat Sport (Space White)
Sales Manager at Torrington Ford
I think you can fit 35's on a 2" level...someone on here has 295/60/20 ko2's without a level. Ford made it so you can run big tires on these trucks in its stock form.
C_Low
Cody
2021 F-150 Lariat Sport
Iv been bouncing around with 275/65/20....285/65/20...295/60/20 Nitto RG. I saw one in person today with the 295ā€™ on the RG and they looked good. I THINK the 285 would be a good middle ground for a taller tire and to wide but not as skinny as the 275. From what I read I donā€™t think any will rub but I donā€™t have my truck get. I already have the 2ā€ ReadyLift at the house waiting. Good post.
Asphaltman
Salt Lake City
Entrepreneur
The only thing I donā€™t understand, ready lift claims on their site that you can install up to a 295/60 20. So the 285/65 20 wouldnā€™t fit??
F150Trucker
Nashville
2021 F150 Platinum
Itā€™s debatable on if a 295/60 or 285/65 is bigger. The 295/60 is 34x11.6 and the 285/65 is 34.6x11.2. So the 295 is a 1/2ā€ shorter but also a 1/2ā€ wider
Also, ready lift says on a 20x9 wheel and the OEM wheels are 8.5 wider.
Iā€™m starting to lean towards the 275/65 and make sure they fit easily. Hopefully they donā€™t look too narrow.
