F150Trucker
Does anyone have a picture of a ‘21 with 275/65 r20 BFG KO2 tires?
Looks great! 2” level? Plenty of room?not 275s
I have 285/65/20 BFG AT k02
2 inch ready lift level. no cutting or rubbing. I wouldn't call it "plenty" of room. But there is enough to not worry about anything.Looks great! 2” level? Plenty of room?
Would there be any concern of rubbing while towing on hills? That's my primary concern for going larger than stock.2 inch ready lift level. no cutting or rubbing. I wouldn't call it "plenty" of room. But there is enough to not worry about anything.
Thanks for the feedback!2 inch ready lift level. no cutting or rubbing. I wouldn't call it "plenty" of room. But there is enough to not worry about anything.
No not at all. Any concern of rubbing would be in the front. Plenty of room in the back. I tow my boat almost weekly and it's great.Would there be any concern of rubbing while towing on hills? That's my primary concern for going larger than stock.
ALso, interested in 2021 with 285/65/20 BG KO2’s,,,, i really don’t want to do lift or level,,, just install these tires,, my confusion is will it rub with nothing else done??Does anyone have a picture of a ‘21 with 275/65 r20 BFG KO2 tires?
Are those in stock wheels? That’s the exact tire size that I want, but I was looking at an aftermarket 20 x 9 wheelnot 275s
Do you know your new cab height? The stock truck is 77.2", which will fit in the garage. I don't have a ton more space to clear the door. Love the look of your truck and I'm also going with a 2" level, but need to be cognizant of not getting too tall of a tire.not 275s
That looks great! What brand level do you have? More pictures would be appreciated. Mine is carbonized gray too and I’m going to get a similar setup.275/65/20 Conti AT's
2" level - no rubbing at all
I had the same tires on my 2018 and towed with no concerns.
Good looking truck! Are you sure those are 275/60 r20? They look bigger than stock.2” readylift level, 275/60/20s. Not rubbing but its super close.... Nitto Ridge Grapplers. +12 offset, 9” wide
Yes they are the stock wheelsAre those in stock wheels? That’s the exact tire size that I want, but I was looking at an aftermarket 20 x 9 wheel
