Pairing H.I.S to the truck (Sync4)
idahospud
Idaho
2022 F150 Lighting, Indian Roadmaster
Commercial Real Estate
Perhaps someone on this forum can assist since Ford, Sunrun, Siemens and Delta have not followed up with my previous correspondence and several open "Cases"...
I would like to summarize where I am in the HIS/Charger connection process:
  • My 80 amp Ford Charger and H.I.S. were professionally installed by a licensed electrician.
  • The H.I.S. is registered with Sunrun.
  • The Charger was successfully connected to my home wifi and subsequently paired with my Android phone.
  • When trying to pair the system with the Sync 4 in my 2022 Ford Lightning, I go through the following:
    • Scan for system (Usually successful in Finding FORD 3000)
    • I log into the Charge Station pro through my Ford Pass app
    • Attempt to Pair “FORD 3000” (the only system found on my screen)
    • AT this point, the Sync 4 asks does this number “__________” match the number on your Charge Station Pro. This is the start of the problem. No number appears on my phone in either app (my phone receives no notification). I have authorized location and notifications on the Ford Pass app and the Charge Station Pro.
    • I have tried to press “yes” to confirm the number matches (even though I can’t see the corresponding number on my phone). The attached screenshot is the message I receive.
I have spent over $10,000 in parts and labor to have a connected home but, to date, I have only a charger. I should note that the system worked in the past buy after a recent update, it lost pairing and I had to start over.
@Ford Motor Company @sunrun @delta @siemens
Ford F-150 Lightning Pairing H.I.S to the truck (Sync4) 20230225_153726
Skidrowe
Gideon
2022 F-150 Lightning ER, 2014 Honda Pilot
Is it referring to a sticker with a number that's on your physical charge station? I vaguely remember having to confirm or enter the number on that sticker.
idahospud
idahospud
Idaho
I am fairly certain it's asking me to confirm that the number that pops up on the Sync4 screen matches a pop-up number on the Ford Charge STation Pro set-up app (to make sure the correct devices are pairing similar to some Bluetooth processes)
