Lightningowner116
How much did the XPEL Stealth wrap cost?? Looks fantastic! Looking to get this done on mine as well.
Thanks,
Thanks,
The full truck was $7500How much did the XPEL Stealth wrap cost?? Looks fantastic! Looking to get this done on mine as well.
Thanks,
AMP is the brandwhich power running boards did you go with? I'm trying to put them on my Pro and haven't found ones that are available yet that fit!
oh got it ok yeah they seemed to be out of stock for a while , ill reach out to themAMP is the brand
Fixed it! See my latest edit to the photos.I feel for people that have to live in Front license plate places.
So you don’t need a front plate in your state? It’s optional?Fixed it! See my latest edit to the photos.![]()
Over 75% of Tesla’s around here do not have front license plates… Around 30% of all other vehicles don’t have license plates… I drove for seven months without a front license plate… Whether it’s legal or not nobody is obviously enforcing it. So if I get a fix it ticket, then I will put it back on.So you don’t need a front plate in your state? It’s optional?
That's the case in a lot of places. I know cops who don't have a front plate on their personal rides.Over 75% of Tesla’s around here do not have front license plates… Around 30% of all other vehicles don’t have license plates… I drove for seven months without a front license plate… Whether it’s legal or not nobody is obviously enforcing it. So if I get a fix it ticket, then I will put it back on.
You could probably find data from non front plate states like PA where the front plate is a waste of money and resources and the rear plate is all the camera systems need (security, tolls etc i.e. The PA Turnpike) to ID vehicles and timestamp their coming and goings.That's the case in a lot of places. I know cops who don't have a front plate on their personal rides.
I'm thinking to draft a bill for our state legislature to remove the front plate requirements, in the interest of "fuel economy". Anybody that can point me to any studies supporting the cause?
Of course, worth mentioning that losing the front plate also makes ALPR (automatic license plate readers) less effective for better (privacy) or worse (identifying wanted criminals).
This is the way.Over 75% of Tesla’s around here do not have front license plates… Around 30% of all other vehicles don’t have license plates… I drove for seven months without a front license plate… Whether it’s legal or not nobody is obviously enforcing it. So if I get a fix it ticket, then I will put it back on.
My truck has no issues with any of the tech since the lift was completed. All works as intended. I had to adjust my speedo with Forscan due to tires being larger. It’s dead on now.Rough Country chat and the 2” level / 3”Lift instructions plus Real Truck all stipulate, “not for trucks with blue cruise”. Did you have any technology issues with the lift and tire change? Blue cruise, lights, speedometer dot dot dot? Thanks.
Thanks. I did the rough country 2” kit this past weekend. No issues until you run thru all the combinations and permutations of hole patterns. The 3 holes in the spacer to mount the spacer on the strut assembly are a no brainer but then there are 4 holes in the frame mount the assembly is reinstalled into for 3 bolts plus 6 holes in the spacer for those same 3 bolts. (For you mathematically knowledgeable it’s 4!x6!/3! possible choices) You need a drinking buddy a flashlight and a marker to help you when you get to this point.My truck has no issues with any of the tech since the lift was completed. All works as intended. I had to adjust my speedo with Forscan due to tires being larger. It’s dead on now.
